EvoScan v2.6 Beta11 now supports EvoX and OpenPort2.0 datalogging
Old Apr 15, 2009 | 12:05 AM
  #31
kaymin's Avatar
no reason why the 2.0 cable wont do any DTC code action?
Old Apr 15, 2009 | 05:49 AM
  #32
pltek's Avatar
did last night
thanks
Originally Posted by evo4mad
log a support ticket at www.evoscan.org/helpdesk you can get a copy sent to you.
Old Apr 15, 2009 | 04:42 PM
  #33
lan_evo_mr9's Avatar
I did another log and noticed something odd. In the beginning of the log, I am sampling about 15-17 samples per second. As the log goes on, it slows down to 4-5 samples per second- max. Any ideas on this?
Old Apr 15, 2009 | 05:17 PM
  #34
tephra's Avatar
can only think of CPU.
dunno maybe a vista thing?
can you use a inverter to power the laptop in the car as a test?
Old Apr 15, 2009 | 05:30 PM
  #35
RAbishi's Avatar
Have you tried enabling/disabling multithreading?
Old Apr 15, 2009 | 05:45 PM
  #36
How do you disable/enable multithreading? I don't have a power inverter for the car. maybe I should invest.
Edit: found the options for disabling multithreading. I'll give it a try tomorrow.
Old Apr 15, 2009 | 06:00 PM
  #37
fostytou's Avatar
EvoM Community Team
Check the "logging" menu. There is all kinds of fun speed related stuff in there.
Old Apr 15, 2009 | 06:07 PM
  #38
What is multithreading?
Old Apr 15, 2009 | 06:41 PM
  #39
I figured out what it is! Whenever I open the real time logging graph while logging, it slows it down. When the graph isn't open while logging- it's super fast.
Old Apr 15, 2009 | 06:43 PM
  #40
tephra's Avatar
Old Apr 15, 2009 | 06:50 PM
  #41
IceFishingLad's Avatar
Anyone else having problems accessing evoscan site this evening? We push it over bandwidth limits?
Old Apr 15, 2009 | 07:02 PM
  #42
MR Turco's Avatar
I cant download either.
Old Apr 18, 2009 | 06:21 AM
  #43
evo4mad's Avatar
access denied was a problem with my Web Hoster company, they have fixed their lame as server up.
Old Apr 18, 2009 | 06:22 AM
  #44
evo4mad's Avatar
I am going to shift web hosting to the United States, this isn't the first time my web hoster has screwed up their server.
Old May 6, 2009 | 10:25 PM
  #45
D-VO's Avatar
I'm having an issue logging in an EVO 8 with the 2.0 cable while using windows XP. I get logs maybe every 7 seconds. I only ticked the necessary tabs in order to properly tune such as rpm, timing, and knock sum (+ whatever evoscan needs to be on to run them), and I have logger super speed enabled with realtime data logging graph disabled. I also tried a 62500 baudrate and I'm seeing no difference.
Now with the 1.3 cable, there is absolutely NO problems logging the EVO 8. I still haven't had a chance to log an EVO X with the 2.0 cable. I should be able to get one tomorrow.
By the way: is there anything that can be done about the slow logging speed of Stiscan?
UPDATE:
OK, I tried to log in an EVO X MR and I'm still having the same problem, under the same conditions but using 500000 baudrate. It only gives me a log once every second. Is there anything else I could do to make this work?
Also, a have a 1.8Ghz processor and 1.5GB of RAM, and I'm noticing the performance graph is in the upper 90% area when using the 2.0 cable.
