EvoScan v2.6 Beta11 now supports EvoX and OpenPort2.0 datalogging
Old Jun 2, 2009 | 03:42 PM
  #76
black2kgsr's Avatar
Along the topic of direct serial logging, does evoscan support direct serial logging with plx devices, ie sm-afr or the new m300? If not, is it on the list of requests for a future release?
Old Jun 2, 2009 | 03:44 PM
  #77
nightfishing's Avatar
Originally Posted by evo4mad
DTCs? I don't think I put that in yet. I will look at that today. should be easy to add.
That would be great.
(and a +1 for SST logging)
Old Jun 6, 2009 | 03:05 PM
  #78
evo4mad's Avatar
Todays priorities for EvoScan v2.6beta13
#2 Update and correct all EvoX formulas.
Old Jun 6, 2009 | 03:20 PM
  #79
evo4mad's Avatar
For those that want to try out the EvoScan with Vista fix, see other evoscan beta thread.
Old Jun 6, 2009 | 05:37 PM
  #80
tephra's Avatar
u including Mode23 support Hamish?
Old Jun 6, 2009 | 07:17 PM
  #81
evo4mad's Avatar
why don't you ask me on msn messenger I already did the version with mode23 last week remember.
Old Jun 6, 2009 | 07:23 PM
  #82
evo4mad's Avatar
I need to connect to your pc with teamviewer to try it out, or you need to be available to try it out for me to make performance adjustments. Please meet me on msn messenger week days from 7pm till 3am NZT or weekends from 4pm till 3amNZT. Thanks.
Old Jun 6, 2009 | 07:26 PM
  #83
evo4mad's Avatar
Tephra, try the beta13 version on the other thread, it is http://www.limitless.co.nz/evoscan/E...a13exeonly.zip you just need to modify the data.xml, or I can send you my one.
I can't get it out of beta because I don't have enough EvoX test users available.
Old Jun 6, 2009 | 07:29 PM
  #84
tephra's Avatar
ill test it when I can.
just tell me how to use the mode23 stuff again?? ill create up a xml for you to use in production.
ps - your not doing the mode10 init are you? (my mode23 hack no longer requires this)
Old Jun 6, 2009 | 09:05 PM
  #85
evo4mad's Avatar
I left you an msn messager about it, its easy. its just how we decided, and I have an xml file I can send you that works, we need to test and debug it together. I also have a whole bunch of questions.
Old Jun 6, 2009 | 09:07 PM
  #86
evo4mad's Avatar
yep I programmed the mode10 init on the version for you last weekend.
Old Jun 6, 2009 | 09:08 PM
  #87
evo4mad's Avatar
if you are online over then next 10 hours, I'll be online if you wanna test and fine tune it.
Old Jun 6, 2009 | 11:10 PM
  #88
onboost's Avatar
Evo X vista64bit logging is working. 72 samples/sec
working on the formula's after dinner
Attached Thumbnails EvoScan v2.6 Beta11 now supports EvoX and OpenPort2.0 datalogging-evoscan.jpg
Old Jun 7, 2009 | 01:08 AM
  #89
SiC's Avatar
SiC
Can you post the new data.xml? I'd love to test it out for you on a JDM EvoX.
Old Jun 7, 2009 | 12:04 PM
  #90
D-VO's Avatar
What exactly do you need as far as an EVO X test?
BTW: Is it possible to get openport 2.0 for Subaru's?
