P0135 CEL Fix for 90550001/98640014?
Old Apr 22, 2009 | 08:46 PM
R. Mutt's Avatar
P0135 is the front heater circuit and I've been trying to figure out what periphery bit to change in order to eliminate this CEL.
I've searched this section of the forum and the only answer I've found is this post to:
Originally Posted by wreckleford
If it is for the front heater, change the periphery 0 to 16D0. This also eliminates the immobiliser and the rear 02.
Old Apr 22, 2009 | 09:33 PM
tephra's Avatar
do you have a front heater in the o2?
Old Apr 22, 2009 | 11:38 PM
R. Mutt's Avatar
There's no heater in the front 02 to my knowledge.
Old Apr 23, 2009 | 11:12 AM
Silvermike's Avatar
This is a JDM evo 6gsr.
The car with the stock e6 ecu throws no code. The car was swapped over to the JDM e7 GSR ecu and threw this code from the get go.
Old Apr 24, 2009 | 07:30 AM
R. Mutt's Avatar
My mistake Tephra...the front 02 on the VI is indeed heated.
Old Apr 24, 2009 | 07:31 AM
tephra's Avatar
ok so you havn't done the wiring quiet right? 7 -> 6 yeah?
Old Apr 24, 2009 | 02:03 PM
wreckleford's Avatar
Changing the 56 to 16 does work. I am not versed in code though. I found it by litteraly turning off and on periphery bits in a logical fashion until I isolated it. I have used it on many cars and have not found any adverse effects, but try it and see for yourself. I woudl love to knwo if there are any other effects that I have not discovered as yet.
Every Evo5 and 6 I have converted has triggered this code, even though the heater wires are on the same pins as the 7/8 and the resistance checks out. I resorted to periphery trickery as a last resort.
Old Apr 27, 2009 | 06:52 PM
R. Mutt's Avatar
Thanks wreckford...I've posted this same question in the MLR forum and everyone had me thinking I was going crazy, or screwed up somewhere. Although I know the wiring was checked several times and the 02 heater circuit was working fine you never know sometimes.
16D0 solved the problem...and strange enough the car has been running MUCH better ever since.
Old Jun 22, 2009 | 07:20 AM
Deepnine's Avatar
Good thread, i checked my complete wiring twice, still had the P0135 error.
Changing to 16D0 worked, and the heater code is gone.
Old Jun 23, 2009 | 01:00 AM
merlin.oz's Avatar
guys, which periphery address are you touching up here?
Old Jun 23, 2009 | 11:46 AM
Deepnine's Avatar
Faa
Old Jul 24, 2009 | 08:04 AM
LeXcite's Avatar
bit.3 at FAA Is it right ?
Old Jul 25, 2009 | 05:56 AM
evonut270's Avatar
FAA bit 14 is the front o2 heater circuit.as wreckleford has said using the perephery code 0x16D0 disables it.iv used it in my e8 ecu conversion into my evo 2.
Old Jul 27, 2009 | 04:17 PM
LeXcite's Avatar
So that is ECU Periphery0 Hex?
There i have 56DA
Should i have to change it to 16DA or 16D0?
Old Jul 29, 2009 | 02:57 AM
LeXcite's Avatar
16DA is just do nothing ... no changes.
16D0 - car not starting, even with right immo hex.
