unable to connect to vehicle interface.???
Old Apr 22, 2009 | 10:14 PM
xspsi4's Avatar
I for some reason can not seem to get my ecu downloaded, Everytime I try this is the message I get"unable to connect to vehicle interface"
The blue arrow (read from ecu's flash memory) is lit up like it should be but when I click that is all I get.
It has been years since I have played with this so I may be forgetting something, I can get evoscan to work if that helps any?
I did not try to use them at the same time so it has the full attention of the cable.
Old Apr 23, 2009 | 03:56 AM
tom04841's Avatar
Do you have and older evoscan openport cable? I had a similar problem. I got a new cable from evoscan, and everything is working just fine now.
Old Apr 23, 2009 | 09:01 AM
xspsi4's Avatar
Yes it is a few years old but It worked then so I am unsure why it would not work now?
Old Apr 23, 2009 | 12:41 PM
xspsi4's Avatar
Anyone? I would really like to start tuning this thing.
Old Apr 24, 2009 | 10:51 PM
xspsi4's Avatar
This is what I am getting
[00:38:46.525] EcuFlash Version 1.41.2483
[00:38:46.525] OS Version Windows Vista
[00:38:46.525] Qt Version 4.4.0
[00:38:46.550] 26 memory models read.
[00:38:46.552] scanning for metadata models in C:/Users/chris/Desktop/EcuFlash/rommetadata
[00:38:47.274] 342 ROM metadata models scanned.
[00:38:47.274] checksum module "subarudbw" loaded.
[00:38:47.274] checksum module "mitsucan" loaded.
[00:38:47.275] flashing tool "wrx02" loaded.
[00:38:47.276] flashing tool "wrx04" loaded.
[00:38:47.278] flashing tool "sti04" loaded.
[00:38:47.278] flashing tool "sti05" loaded.
[00:38:47.279] flashing tool "mitsukernel" loaded.
[00:38:47.279] flashing tool "mitsukernelocp" loaded.
[00:38:47.279] flashing tool "mitsubootloader" loaded.
[00:38:47.279] flashing tool "shbootmode" loaded.
[00:38:47.289] flashing tool "shaudmode" loaded.
[00:38:47.289] flashing tool "subarucan" loaded.
[00:38:47.291] flashing tool "mitsucan" loaded.
[00:39:03.354] Using interface OpenPort 1.3 Universal TX2679tUb148f6d50ff22adeadea446559104aacc667a9a7
[00:39:03.355] interface close
[00:39:03.364] unable to connect to vehicle interface.
[00:40:01.093] Using interface OpenPort 1.3 Universal TX2679tUb148f6d50ff22adeadea446559104aacc667a9a7
[00:40:01.093] interface closet
Old Apr 24, 2009 | 11:24 PM
xspsi4's Avatar
I think I may need an older version such as 1.29 or so?
Old Apr 26, 2009 | 04:20 PM
xspsi4's Avatar
Ok this is really getting fustrating, I am sure someone has to have an idea where to look?
I can't believe the lack of support in this section, I started to get in to this because at the time it looked like there was tons of support but I can't even get my rom to dl to my computer.
What gives here?
Old Apr 27, 2009 | 06:35 AM
fostytou's Avatar
EvoM Community Team
Originally Posted by xspsi4
...I can't believe the lack of support in this section...
If you are having trouble here you are welcome to visit the ecuflash / openecu forums... we're all doing this for free
Try v-1.29, if that works then you need to update your cable or get a new one.
Old Apr 27, 2009 | 07:50 PM
xspsi4's Avatar
Yea sorry if came off a little upset but it just seems like whenever I post a tech ?? on this forum it usally ends up just sitting un answered for ever which is kind of hard for a diy guy like myself who usally just needs a point in the right direction
Do I have to erase the newer version and then dl the new?
Where on openecu.org do I get the older version?
Thanks for the response!!
Old Apr 28, 2009 | 11:29 AM
GTijoejoe's Avatar
Make sure you double check your COMM ports.
I just reloaded 1.29a the other wk and I got the same error. Than I rechecked my COMM port and it was wrong, quick fix.
Old Jun 13, 2009 | 01:52 PM
MRevo8maniac's Avatar
I'm having the same problem as XSPSI4. Any help would be greatly appreciated.
Thanks
Old Jun 13, 2009 | 04:26 PM
mt057's Avatar
[QUOTE=xspsi4;6975131]I for some reason can not seem to get my ecu downloaded, Everytime I try this is the message I get"unable to connect to vehicle interface"
I did not try to use them at the same time so it has the full attention of the cable.[/QUOTE
What operating system are you using? I had this problem. I checked all my fuses made sure all the wires in the back were in tight and it suddenly worked again. It is probably something easy to fix and a pain in the wazoo to figure out.
Old Jun 13, 2009 | 08:06 PM
EcuFlash 1.29a
Finally got EcuFlash 1.29a here:
https://www.evolutionm.net/forums/ec...e-link-me.html
Reading the ECU finally worked. V1.41 did not.
Old Aug 19, 2009 | 10:42 PM
nipe's Avatar
I can read ECU with 1.29, but no luck with 1.42. What exactly has changed in the cable?
Burnhad91
Nov 10, 2015 02:43 PM
Fuchsig
Jul 14, 2015 06:34 AM
17579EVO9MR
May 30, 2012 08:00 PM
Jeeperjunior
Jul 18, 2008 05:25 PM
Warrtalon
May 30, 2006 04:51 PM
