Tuning Fuel 2009
Old May 20, 2009 | 06:43 AM
Appauldd's Avatar
It takes a lot more time to tune with LS on. You have to do a ton of pulls and tweekeing until you get it consistant from pull to pull.
Tune it just as you would with LS off. Shoot for the same AFRs. Just be aware that your Fuel table will never match your actual AFRs.
As for the question about being a full point leaner if you are tuned without LS......the statement is correct. You will be about 1 full point leaner with LS on.
Old May 20, 2009 | 06:53 AM
MR Turco's Avatar
you lean spool enabled guys. What adjustments are you making to your lean spool specific tables? I find it interesting that you can actually utilize lean spool.
Old May 20, 2009 | 07:20 AM
Appauldd's Avatar
I'll start another thread about tuning with LS enabled. Hopefully 03whitegsr will chime in too.
Old May 22, 2009 | 10:13 PM
03whitegsr's Avatar
Factory lean spool values will make a car tuned for 11.5:1 AFRs in the main table run almost 13:1 on initial onset of higher loads.
I would recommend against tuning the car with lean spool disabled and then turning it on without adjusting the target AFR table to more conservative values. This is a sure fire way to at the very least **** off the knock sensor.
Old May 23, 2009 | 06:34 AM
Appauldd's Avatar
That's the truth.....I learned the hard way.
jrainwater
May 16, 2014 02:45 PM
07EvoIX
Oct 28, 2012 12:49 PM
richardjh
Jun 18, 2011 10:16 AM
Clipse3GT
16
Jul 25, 2010 11:14 AM
RoadSpike
Sep 30, 2007 05:42 AM
