where to find boost definition for ralliart
Old May 2, 2009 | 09:52 PM
awddyno's Avatar
This is what I found. Do these tables need to be defined first? I pretty sure I can't just alter it.
Old May 2, 2009 | 10:04 PM
tephra's Avatar
yeah they are not correct.
you need to convince a disasm person to find the proper def's for you
Old May 2, 2009 | 10:14 PM
awddyno's Avatar
Any volunteers?
RomID 536000010
Send me your email and I'll send the rom. I don't think I can post it here.
Old May 2, 2009 | 11:00 PM
tephra's Avatar
ive already got that rom.
i havn't looked for the boost defs yet.
ummm if no-one else helps you out i will look up the boost defs tommorow.
i already got the torque/airflow limits done
Old May 3, 2009 | 06:11 AM
awddyno's Avatar
Tephra I know you got other things to do, but so far you're my only help. If you can squeeze this in when you have time that would be great. Or has anyone just flash it with a rom already defined?
Old May 3, 2009 | 11:42 AM
GST Motorsports's Avatar
The ralliart only has the reactive 3D boost maps. It only has a single solenoid. The secondary passive solenoid 1D maps do not exist.
Old May 3, 2009 | 02:04 PM
Danieln's Avatar
Check this out mate
But be sure that you will ask somebody who can confirm that this are the right tables.
Take care
Attached Thumbnails where to find boost definition for ralliart-ral-boost.jpg
Old May 3, 2009 | 02:13 PM
Originally Posted by Danieln
Check this out mate
Take care
See my post #6.
09 Ralliarts only have a single solenoid.
The 3D reactive boost maps only apply. The passive 1D maps do not apply.
Just editing the stock 3D boost maps can give you a bit more boost as they drop from 100% duty cycle up top, but to really get more boost tuned in you need to upgrade the boost pill:
Here is the *stock* WGDC 3D table:
Old May 3, 2009 | 02:48 PM
Danieln's Avatar
As I said,
Somebody need to agree on this...
This is the stock map that I have.
I saw your post very clear but this is also a stock map for SST.
Maybe Dave can confirm your version and everything will be more clear.
Take care
Old May 3, 2009 | 02:50 PM
As I said,
Take care
You are looking at the passive 1D maps. look at the reactive 3D maps.
The reason why you can even "see" the passive 1D maps in ecuflash with the Ralliart ROM open is because the Ralliart uses Evo10base. Personally I think Ralliart should have it's own base file so this type of confusion doesn't happen.
it is 100% correct, I have tuned a handful of Ralliarts so far...
Old May 3, 2009 | 02:56 PM
Danieln's Avatar
I just add passive solenoid base wgdc not the boost table
And Yes .......this is the same map.
Adding wgdc map2
Attached Thumbnails where to find boost definition for ralliart-wgdc-map2.jpg
Old May 3, 2009 | 03:08 PM
Adding wgdc map2
This is getting confusing.
There are no passive 1D WGDC maps on the 09 Ralliart.
There are reactive 3D WGDC maps on the 09 Ralliart.
The 09 Ralliart has a single boost control solenoid, not two like the Evo 10
The addresses for the 09 Ralliart reactive 3D WGDC maps (only ones that apply for the 09 Ralliart) are:
<table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58d39">
<table name="Throttle" address="62672"/>
<table name="RPM" address="625f0"/>
</table>
<table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58de3">
</table>
<table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="57393">
</table>
Old May 3, 2009 | 11:32 PM
Danieln's Avatar
This is my definition file
Check this out please......
</table>
</table>
</table>
Old May 3, 2009 | 11:51 PM
That is what I posted above
Those are the correct addresses for the WGDC tables for the 09 Ralliart
Old May 4, 2009 | 12:43 AM
Danieln's Avatar
Exact
I have same definition like yours
