EcuFlash BUG on E6 GSR ECU !!!
Old May 8, 2009 | 09:45 AM
  #31
cardiag's Avatar
Originally Posted by Mattjin
A timely warning for others here. This is part of open source..... little or no support except for the community. Honestly, if this was not open source we would be paying ALOT more money for the cables and software. Look at what it costs to obtain reflash capabilities for other vehicles and you will see what I mean.
You say at 5mins it turns off? Does it hard turn off or slowly die down and stall?
I am quite interested in your problem, because the last thing I want to do is flash a similar model and have issues.
just like for end of fuel every time
after that i connect with notebook without turning off the ignition key and evoscan can made datalog and no fault codes!
In attachment is logfile and car slowly die down and stall at 1:50sec !
Old May 8, 2009 | 11:44 AM
  #32
kc427's Avatar
your logfile looks very strange, eg, the rpm can suddenly changed from 1xxxrpm to 5xxx rpm
Old May 8, 2009 | 01:53 PM
  #33
cardiag's Avatar
where ? after time 150 is the problem
Old May 12, 2009 | 06:40 AM
  #34
cardiag's Avatar
Support of tactrix is very poor and they don't answer on my emails !!!
Old May 15, 2009 | 11:28 PM
  #35
cardiag's Avatar
Do not buy this cable for evo 5-6 ECU !!!
Old May 15, 2009 | 11:47 PM
  #36
burnzy's Avatar
dude you haven't even ascertained as to what the real problem is and you go around bagging software that you got for free and came with a "use at own risk" statement. There's been plenty of people that have flashed their 6 ecus fine.
Old May 15, 2009 | 11:51 PM
  #37
D420mac's Avatar
Freaking Bulgarians, Zdrave, As rasperim malco Bulguski. I don't know how to type it in English!!! good Luck!
Old May 16, 2009 | 12:04 AM
  #38
jimn's Avatar
When you flash your stock rom back in do you adjust the stationary rev limit or leave it alone?
I know on my 7 the limit doesnt do anything so your not supposed to change it at all!
Have you got hold hold of a completely stock map - NO CHANGES MADE WHATSOEVER and flashed that in?
Old May 16, 2009 | 12:08 AM
  #39
GST Motorsports's Avatar
by all means go purchase EcuTek for thousands of dollars instead of free then.
Old May 16, 2009 | 12:47 AM
  #40
cardiag's Avatar
razbirash mi uq
Old May 16, 2009 | 12:53 AM
  #41
evonut270's Avatar
there is nothing wrong with the cable.if you had done your homework before messing around this wouldnt have happened.no point blaming the product.no one told you to use it.
Old May 16, 2009 | 03:16 AM
  #42
cardiag's Avatar
and also the seller dont write that there is bug for evo6 and cannot be fixed !
Old May 16, 2009 | 03:17 AM
  #43
cardiag's Avatar
And what you think when i put file from original ev 5 or 6 GSR and problem is same a?
Old May 16, 2009 | 08:59 AM
  #44
It makes me think you are doing something wrong.
Old May 16, 2009 | 09:13 AM
  #45
evonut270's Avatar
the ecuflash software is free.its a software fault not the cable as iv said before.there has been postings on both the mlr and geekmapped that there is a fault.you wont find it on here as most dont have a 5 or 6.
