EcuFlash BUG on E6 GSR ECU !!!
Old May 3, 2009 | 12:15 AM
cardiag's Avatar
Hello all
I have big problem after reflashing my E6 ECU with EcuFlash and noone can help me till now . I write to Colby (developer) but no result. Problem is that i change only speed limiter and reflash my ECU than every 5min ECU is switched off itself just like time bomb and engine run only at idle speed up to 1500rpm. I connect with different equipment for diagnostic including evoscan 2.6b and no fault codes ! All live data prameters is ok up to 5min after starting ! I mean that you can start car and car run normal but only 5min ! After that you need to switch ignition off than start again for another 5min .... Its 100% ECU reflash BUG due to EcuFlash software because i use other ECU and all is normal ! A made other test to proove that is bug and this ECU is damaged : i unmount all plastic covers behind gear selector and i find relays for EFI and Fuel pump. I just put bridge on place of EFI relay without starting of car , just ECU to have power on ! Than after 5-6 min i start the car and problem is same - only idle speed I try to reflash with original untouched file for that ECU but same result . EcuFlash write to some wrong areas and i cannot have salution to resolve the problem Maybe its good idea to find E7 ECU but i cannot find at the moment to buy
Old May 3, 2009 | 01:24 AM
tephra's Avatar
why dont you flash the original rom back and see if that fixes it?
Old May 3, 2009 | 01:37 AM
cardiag's Avatar
I try several times but is same !Now i am with file for EVO5 some original from geekmapped and no change Also i try with other files and ECU stop on every 5min ...just idle speed .In attachment is mine ECU
File Type: zip
Old May 3, 2009 | 02:10 AM
SkyNight's Avatar
If you flash the original rom back the problem (probably) is EcuFlash. Only Colby can help you.
Old May 3, 2009 | 03:36 AM
cardiag's Avatar
yes but he dont answer on my emails
someone sell E7 ECU?
Old May 3, 2009 | 05:58 AM
SkyNight's Avatar
Our moderator sell an EVO VII RA ROM
Link: http://www.lancerevoclub.com/communi...hp?f=2&t=10906
Old May 3, 2009 | 11:52 AM
THUB's Avatar
Could this be an immobilizer problem? I'm not sure if the VI even had one but is sounds like it in my head
Old May 3, 2009 | 11:59 AM
cardiag's Avatar
i disable immobilisers every day and 100% of cars cannot run or start than immidiately turn off ... no such problem with any brand car Also if this is immo problem than why no fault codes???
maybe i can disable but what to put in immo fields?
Old May 3, 2009 | 02:38 PM
THUB's Avatar
I'm pretty sure there is no fault code for an immobilizer. I don't know much about them, or even if your car has one, It just seems weird that your car is running for a little bit then deciding not to. Which is why I'm saying that might be the problem.
Old May 3, 2009 | 02:42 PM
cardiag's Avatar
Its not little its exact 5min after start every time .
Old May 3, 2009 | 03:03 PM
THUB's Avatar
That's really odd. I'm really sorry I can't be of more help.
Old May 4, 2009 | 12:47 AM
cardiag's Avatar
I just try with Rallyart file and now its not 5min its 10min
Old May 4, 2009 | 01:56 AM
cardiag's Avatar
Originally Posted by evogirl916
thats f'd. i wouldn't do anything until you talk to someone solid...you sont want to f anything up
Its f...ed evoscan BUG !
Old May 4, 2009 | 03:09 AM
cardiag's Avatar
I write RA rom in attachment and car dead after 10min. I just back my original file that i post up in topic and now also is 10min timer That is small salution
In both files i try to change stationary rev limiter value but is not working ! The question is : what kind of TME upgraded Rallyart super NASA dump i need to flash to solve the problem ?
File Type: zip
Old May 4, 2009 | 05:54 AM
kc427's Avatar
so do you mean yours is EVO6 TME version?
