Mitsu 3-bar MAP sensor calibration
Old May 12, 2009 | 12:55 PM
roger smith's Avatar
I was wondering, I've heard not all sensors (in general) are made the same so each sensor will need to be calibrated when used.
The current implementation of using the Mitsu 3-bar MAP sensor to log boost lays out a set calibration table for people to use. Shouldn't people be calibrating and inputting their own values in those tables?
Or are all these sensors so close that the differences are minimal?
Old May 12, 2009 | 01:21 PM
fostytou's Avatar
EvoM Community Team
The differences in OEM sensors are generally very minimal. Mitsubishi doesn't calibrate every MDP/MAP sensor when they put it in, or any of the other sensors for that matter. There is likely a tolerance range that every OEM sensor is tested against before leaving the factory. If the sensor is not calibrated during it's production, it is not calibrated at all in OEM applications.
Aside from the fact that most people don't have the means to do so, the range of variation is probably not large enough to worry about.
06Black
Jul 6, 2016 12:43 PM
jameswwt
Aug 1, 2015 03:32 AM
fritzevo
Dec 21, 2012 12:20 PM
03whitegsr
Jan 17, 2011 06:02 AM
Kracka
Sep 22, 2008 07:23 PM
