VE calibration for AVCR map use in SD mods
Not right off. Need to know exactly what bar it is, is it linear, does it have a voltage vs psi/kg-mm/bar reference sheet or can you get it with a boost leak check? If you had all that data its fairly easy to spreadsheet. As irritating as that all is you may find it easier and cheaper to buy an Omni 3 bar or 4 bar or the factory 3 bar sensor.
Aaron
Aaron
06Black
Jul 6, 2016 12:43 PM
Dynotech Tuning
Oct 2, 2013 03:39 PM
