sd map ve calibration column missing?
Old Jul 3, 2013 | 01:16 AM
turbodailydan's Avatar
im trying to setup my sd map ve but the left column is missing, any ideas? It wont let me input any data into the empty columns either
I see it is empty when i attempt to edit so i added map16 bit to the left column but i still cant input anything into them.
Old Jul 3, 2013 | 05:29 AM
evo8426's Avatar
Change the scaling on the Y-axis MAP at the bottom to either "kPa OMNI4barMAP" or "kPa JDM3barMAP" depending on which MAP sensor you have installed.
Old Jul 3, 2013 | 08:08 AM
domyz's Avatar
Dan you have a GM 3 bar, make sure you set the scaling correctly. Make sure your XML wasn't corrupt. I don't know what made this to happen, because when you download the v7 xml pack this is properly set up (omni4bar).
Old Jul 4, 2013 | 04:30 AM
Yes im running a gm3bar however neither that or the 4bar is listed on the drop menu for some reason.
Anyone got another 2d sd xml i can try for 9531706 ?
Old Jul 4, 2013 | 04:37 AM
domyz's Avatar
You need those 2 xmls. SD specific tables are in 96531* and scalings+other tables are in 96530*.
File Type: xml
File Type: xml
Old Jul 4, 2013 | 04:57 AM
Will check tonight. Maybe i only have one of them xmls hence the lack of scaling.
Old Jul 4, 2013 | 11:36 AM
already had those xml's in there but i replaced them with the ones above and now works thanks
WickWhiteEvox
Cobb AccessPORT
Mar 12, 2017 09:50 PM
423evo8
Oct 8, 2016 08:15 PM
Jonathan Brito
Aug 5, 2016 02:16 AM
10kLakesEvo
May 30, 2014 08:26 PM
csra09
Mar 14, 2012 10:55 AM
