AEM EMS Get tuning help for your AEM EMS system.
MAP Sensor Calibration
Old May 18, 2008 | 11:04 AM
chuckbyu's Avatar
Does anyone know what the calibration is for a GM Map sensor with number 103 3160 stamped on it is? Thanks.
Old May 20, 2008 | 09:31 AM
chuckbyu's Avatar
Ok new question. I'll just calibrate the MAP myself. In the MAP Sensor Options window, there is Max Voltage, Min Voltage, Filter, Load Offset, Load Scalar, and Frequency #4 Div. I know what the max and min voltage is, can anyone tell me what the other things mean? I couldn't find it in the instruction manual anywhere. Thanks.
Old May 24, 2008 | 08:09 AM
chuckbyu's Avatar
Nevermind. THanks.
Old Jun 7, 2008 | 11:36 AM
EvoKnievo's Avatar
Originally Posted by chuckbyu
Nevermind. THanks.
post the answer!
what is the correct way to scale that MAP sensor?
Old Jun 8, 2008 | 07:40 AM
tseitz123's Avatar
MAP Sensor
There are 3 wires on a MAP sensor. It requires MAP signal, 5V reference, and sensor ground. If you're using an AEM MAP sensor: MAP signal is green or white, 5V reference is red, and sensor ground is black. The signal wire needs to be dedicated, meaning that should be the only wire making contact with that pin. The sensor ground and 5V reference wire can be tapped. Please follow the pin out below to wire in your MAP sensor. If you did everything correctly, with an AEM 3.5 bar MAP sensor, your MAP voltage (setup/sensors/map sensor parameters) should be about 1.6V with the key on engine off, with an AEM 5 bar MAP sensor, your MAP voltage should be about 1.3V with the key on engine off. Remember to select the correct sensor in your MAP sensor wizard.
Off of the AEM Forums. Hope this helps. I guess you can use these voltages mentioned as a base line for the MAP sensor calibration table.
Old Jun 8, 2008 | 05:11 PM
chuckbyu's Avatar
Sorry EvoKnievo, I gave up. Never found the answer. I just bought a 3 bar MAP the was already calibrated in the Map Sensor Wizard. I would still be interested in the answer if anyone has it.
Old Jun 13, 2008 | 12:26 PM
tunermt's Avatar
you could always calibrate the sensor your self with a volt meter, 5 volts, boost gauge and a small air pump,
hahaha not sure if its worth the trouble though! MAP sensors are really not that expensive and if AEM has done a REAL calibration already better safe than sorry!
3011carlos
Jun 9, 2017 07:20 PM
211Ratsbud
Dec 22, 2016 02:12 PM
06Black
Jul 6, 2016 12:43 PM
Wicked E
11
Apr 28, 2008 03:48 PM
nutrulz
AEM EMS
Mar 4, 2006 07:06 AM
