Knock on shifts.. Help
Old May 14, 2009 | 06:11 AM
Silvermike's Avatar
Hey guys,
I'm running 22psi tapering to 20 on a evo 9 turbo, straight 91 oct. This same tune was tuned last weekend to 341hp. What Ive notice since I got off the dyno is that the car knocks on the shift.. sometimes. Ive tried pulling timing from the cells i hit during the shift but the problem persists. Any advice on how to stop it?
Old May 14, 2009 | 06:17 AM
Mellon Racing's Avatar
it's in the tune, a common problem for novice tuners
Old May 14, 2009 | 06:23 AM
Silvermike's Avatar
i sucky sucky
Old May 14, 2009 | 06:39 AM
jcsbanks's Avatar
You can see the jump up in timing on lift off that causes it. I put a plateau in the timing in the lift off areas, sometimes up to 5 degrees in the parts of the 140-240 range.
Old May 14, 2009 | 05:54 PM
Silvermike's Avatar
Thanks, problem solved!
Old May 15, 2009 | 01:07 AM
Lazyfong's Avatar
Can you post your map to show what you did? Having same problem as well.
Old May 15, 2009 | 11:49 AM
Silvermike's Avatar
As jcsbanks said. When I map traced the shift i saw that my load ran up and down the 7500 load cells.
My load at 7500 is about 220 under WOT. On the shift, it ran down to about 40-60 load and then back up to 200ish all in the 7500 row. What i did was pull timing along the 7500 row so that the timing comes more smoothly back to the 14* or so I have in my 220load cell.
Also to solve the knock caused by shifting at the other rpms (ie shifting @ 6k say) i applied this method to all columns from 140load -220 load from 5500-7500.
fi8tzer0
May 7, 2016 07:33 AM
Kracka
Jul 23, 2009 04:26 PM
evil_eagle
Nov 16, 2008 12:37 PM
kkarim
May 22, 2008 11:43 PM
Jeff_Jeske
Aug 6, 2007 10:41 AM
