knock after a NLTS
Old Jul 1, 2009 | 08:27 PM
Kracka's Avatar
knock after a NLTS
Most times after a good fast NLTS I will register knock. I'm almost positive that its not real knock b/c if I shift normally I don't get any knock. I've heard a few other people complaining about this type of condition too. Anyone know of a fix for this?
Old Jul 1, 2009 | 08:59 PM
andrewzaragoza's Avatar
log the event and adjust the timing on those cels where it is hitting. its round the 80-160 load area at high rpm if i remember it right.
Old Jul 1, 2009 | 09:10 PM
silver_evo's Avatar
Yep, it'll do that. Its a great addition for shifting fast and safely. But, it will kill your pull with knock sum. I reduced timing in the 5k-ish area and 120-160 load. Thats where my NLTS lands. If you think about it, moderate boost (11 psi due WG spring and WGDC at 0% during fuel cut) + lean mixtures during fuel cut + advanced timing = Knock!!
EDIT: Also 2-step launch (stat rev limiter) about 4.5-5k will produce the same knock!
Old Jul 2, 2009 | 04:13 AM
rolly1818's Avatar
Registered User
5000 to 7000 rpm area and 100-160 load, make it a buch of low timing values to ensure knock
Old Jul 2, 2009 | 07:02 AM
Thoe99's Avatar
How low is low?
Old Jul 2, 2009 | 07:17 AM
rolly1818's Avatar
Registered User
about 15-20 i would say it all depends on ur map.
Old Jul 2, 2009 | 07:48 AM
Kracka's Avatar
Good suggestions so far. I'll go out logging and figure out what RPM/load ranges its hitting and knocking at.
Old Jul 23, 2009 | 01:12 PM
Kracka's Avatar
I reduced my timing by 4* and richened my fuel up .2 AFR in the load 120-160 and RPM 4000-6000 areas. We'll see if this helps!
Old Jul 23, 2009 | 04:26 PM
rolly1818's Avatar
Registered User
drop it more than 4* IMO.
how is NLTS with the competition clutch?
how is it treating ur gearbox?
stunt2
Aug 18, 2011 08:53 AM
BoostFTW05
Feb 22, 2010 09:24 AM
TouringBubble
Feb 11, 2008 02:01 PM
XBS
Oct 17, 2007 11:02 AM
TouringBubble
Oct 15, 2007 04:05 PM
