PLX R-500 wideband
Old May 23, 2009 | 08:52 AM
evonut270's Avatar
PLX R-500 wideband
im thinking of getting one of these but i need to know if it will work with evoscan.also would like some feedback if you have/had one.
Old May 23, 2009 | 01:11 PM
turbolarry's Avatar
It could, but the plx r-500 has it's own data logging;
http://www.plxdevices.com/Installati...tion_F1.11.pdf
... and the only way I've been able to find a plx to work is through the rear O2.
If you are just looking for simple plx wideband maybe try the sm-afr. It has a 0-5 volt output that can be fed into the rear O2 signal. I just put one in two days ago and the only problem I've had is that it trips a check engine light for the O2 voltage being high. So far it is working just fine with evoscan version 2.0
Old May 24, 2009 | 08:37 AM
SWOLN's Avatar
+1 on the Evoscan support for the PLX devices.
Ralliartize It
Jul 16, 2013 03:28 AM
ODUB
Site Feedback / Suggestions
Mar 9, 2011 02:59 PM
bouncintiga
Nov 18, 2009 12:14 PM
MitsuEvoIIX
Nov 13, 2005 08:27 AM
