psi based boost on a BBK?
Old May 23, 2009 | 05:42 PM
nothere's Avatar
hi,
Anybody got PSI based boost control running a BBK and a stock block like to give me a basic idea where to start my wastegate maps at?
I had some unusual entries when I tried load based control last fall. Since I now am trying Trepha's latest xml thought I'd drop the mbc.
Just thought if I could start most of the way there I could reduce my time on on ramps.
Seems like I'm seeing a lot more enforcement than usual around here.
Old May 23, 2009 | 11:14 PM
Appauldd's Avatar
The stock maps are always a great place to start.
Tweek them little by little and eventually you will be where you want.
This is the answer most will give you on here. No one really shares maps because every car is different and everyone tunes a little different as well.
Just being honest.
Old May 23, 2009 | 11:20 PM
nano's Avatar
Blue full, ported. I'm not pushing the turbo because im on stock block and crappy 91 here in CA. Running at a VERY conserative 21.5 psi. Holds with little to no boost error with these values.
Hope this helps.
Old May 24, 2009 | 05:49 AM
nothere's Avatar
thanks nano, that gives me a place to start. I might have started doing the opposite.
Appauldd, I don't have any idea where I would find a stock map. I think the maps are zeroed by Tephra.
Old May 24, 2009 | 06:27 AM
MR Turco's Avatar
Wow you can tell from the table how much boost this turbo makes up top.
Old May 24, 2009 | 10:43 AM
scheides's Avatar
EvoM Moderator
BBK full, bad@ss port job from Bob @ MAP, oem WGA, with GM BCS fed off of the stock compressor outlet pipe.
Holds right around 24psi all the way across the powerband, as seen in this graph:
The upper map is with alky on, wgdc cranked up a bit more. A typical full bolt-on IX on this dyno will make ~320whp on this dyno, so this turbo is *excellent* on pump gas
Old May 24, 2009 | 10:52 AM
nothere's Avatar
is there a reason I have a new p1400 code ?
manifold pressure fault
Old May 24, 2009 | 11:22 AM
scheides's Avatar
EvoM Moderator
Did you do the hack for the evoX/JDM map sensor as well as the direct boost mod? Double check your work
philr8
Nov 24, 2010 08:38 AM
CornFedEvo
Dec 4, 2009 09:43 PM
GST Motorsports
Dec 1, 2009 06:49 PM
house_of_senate
Oct 5, 2009 04:33 PM
9sec9
210
Jan 20, 2009 04:38 PM
