Evo X Logging
Old Jun 15, 2009 | 07:12 PM
  #346
tephra's Avatar
Please do - although as I said I am not sure how quickly the sensor reacts because of the heat soaking nature of the I/M.
Code:
RPM  PSIG  I* KS LOAD VSS IAT CAT
4566 18.58 15 0  224  60  14  31
4781 20.76 14 1  242  60  14  31
4863 21.58 12 1  246  60  13  31
5023 21.63 13 0  245  60  13  31
5140 21.49 14 0  241  60  13  31
5320 21.34 15 0  236  60  13  31
5394 20.76 17 0  232  60  13  31
5589 20.23 18 0  226  60  13  31
5691 19.65 18 0  223  60  13  30
5843 19.41 18 0  222  60  13  30
5957 19.12 18 0  221  60  13  30
6097 18.78 18 0  219  60  13  30
6183 18.44 18 0  216  74  13  30
6355 17.52 18 2  212  74  13  30
6394 12.39 21 1  155  74  13  30
Old Jun 15, 2009 | 07:34 PM
  #347
LaXGSR's Avatar
Thanks guys! I'll try out the updated Data.xml tomorrow night. Tephra, in the log you posted, which one is manifold temperature, so I can compare my results. Thanks!
HiBoost, it would be great if you could take logs too for reference. I'll post up my results as well.
Old Jun 15, 2009 | 07:36 PM
  #348
tephra's Avatar
Charge Air Temp (CAT)
Old Jun 15, 2009 | 11:20 PM
  #349
mrfred's Avatar
Updated mode 23 Data.xml file attached for 52680015-20 USDM GSRs. WGDC values have been verified, and have added entries to log all the different loads.
Old Jun 16, 2009 | 06:09 AM
  #350
mrfred's Avatar
Updated again to include what I suspect to be accelerator pedal position.
Old Jun 16, 2009 | 06:30 AM
  #351
pltek's Avatar
is the AFRMAP for logging wideband?
Old Jun 16, 2009 | 06:38 AM
  #352
hameedosh's Avatar
hi mrfred
are those xmls for evoscan ??
Old Jun 16, 2009 | 07:09 AM
  #353
mrfred's Avatar
Nope, its the target AFR.
Originally Posted by hameedosh
hi mrfred
Its just a Data.xml file for EvoScan 2.6b14 for use with the USDM Evo 10 GSR.
Old Jun 16, 2009 | 09:40 AM
  #354
criptballer's Avatar
dont mind the stupid question but, whats the target AFR table for?
also, has anyone made their own RS232 cable to log with evoscan, i'm attempting to do that today, but my comport on my laptop doesnt work, so now i have to buy a USB to comport cable.anyone done this yet?
Old Jun 16, 2009 | 09:49 AM
  #355
mrfred's Avatar
Its the target AFR that the ECU uses to set IPW. When the car is in open loop, it comes from the fuel tables. When the car is in closed loop, its set at 14.7:1. Its not the actual AFR though. A wideband is needed to measure actual AFR. AFRMAP is just a tool to see how the target AFR is comparing to actual AFR.
Old Jun 16, 2009 | 10:01 AM
  #356
pltek's Avatar
can you put the wideband back in the data.xml file?
Old Jun 16, 2009 | 10:05 AM
  #357
mrfred's Avatar
Yes, later today. Or you can do it yourself using an older Data.xml file that has the wideband entry.
Old Jun 16, 2009 | 12:04 PM
  #358
anybody have any input on my RS232 cable issues?!?
Old Jun 16, 2009 | 12:24 PM
  #359
LaXGSR's Avatar
All you need is a good USB to serial converter. I'm assuming this is to hook up your serial wideband o2 input? Look in the evo 9 ecuflash subforum for a thread discussing serial converters that work. I got mine off Amazon (it got pretty good reviews) and it seems to work fine. Radio shack also has some that will work.
Old Jun 16, 2009 | 01:40 PM
  #360
crcain's Avatar
Sorry to report but I tried logging a few days ago with my friends X again and had no luck. I was able to connect with EvoScan but the logging rate was like incredible slow. Also the values logged were innacurate it seems. Here is a little screen grab of the Excel output:
Everything else looks a mess. This is from the 52360016 rom. I tried to upgrade to the 52360018 rom but when I opened this rom in EcuFlash I seemed to be missing the rom meta data for the inherited rom id. I got this message:
[16:38:05.666] Unable to find parent metadata 52370024
So does someone have the meta data for the above inherited rom id?
And in terms of the data.xml, can anyone confirm the data.xml that comes with beta14 actually has the correct data.xml definitions for the 52360016 or 52360018 roms? As in did someone actually do it and it worked?
Also logging rate is one per second which is obviously practically unusable. Is there any effect com port settings or anything can make? I have log to file, no log to screen, disable mutli-threading, etc...
Does the baud rate in the OP 2.0 settings have any effect?
