Evo X Logging
Old Jun 2, 2009 | 05:26 PM
  #31
SiC's Avatar
SiC
The 53040007 addresses didn't match up on the JDM
Old Jun 2, 2009 | 05:34 PM
  #32
tephra's Avatar
send me the rom dude - ill work them out for you.
myforumname @ gmail.com
Old Jun 2, 2009 | 05:42 PM
  #33
SiC's Avatar
SiC
Sent from hotmail!
Thanks
Old Jun 2, 2009 | 06:03 PM
  #34
tephra's Avatar
first post updated with XML's for some ROMID's.
You can use the zip in the 2nd page - but you will have to update the Hex Address's...
Old Jun 2, 2009 | 06:04 PM
  #35
SiC's Avatar
SiC
You ROCK!!
Old Jun 2, 2009 | 06:07 PM
  #36
tephra's Avatar
that 52360018 rom is a bit screwy SiC - the XML should work - but just be a bit cautious when you after you flash...
Old Jun 2, 2009 | 06:12 PM
  #37
SiC's Avatar
SiC
Yeah, I noticed I sent you an old ROM that we used in the old ECUFlash beta before it supported the correct checksum on the EvoX. I tested the address out with another ROM and it seems to work fine.
BTW, can I send you one more: JDM 52370024 (SST), this one didn't seem to all line up either.
Thanks again!
Old Jun 2, 2009 | 06:14 PM
  #38
Deepseadiver's Avatar
This is great news! When will I be able to use EVOscan with no problems? Or a "how to" log an evo X thread?
Old Jun 2, 2009 | 06:49 PM
  #39
LaXGSR's Avatar
Tephra, this worked great on a stock USDM GSR with 52680018. Looks like it's pulling a degree or two of timing up top above 6500 rpm's. How do I interpret the knock sum value - I see a few 1's and 2's up top. Is this a count like the evo 8/9 where 3 counts equals 1 degree, or does 1 count equal 1 degree roughly?
I've attached my log. Any chance of getting TPS and wastegate duty cycle? Thanks again
File Type: txt
Old Jun 2, 2009 | 07:13 PM
  #40
Hiboost's Avatar
I'm pretty sure it's normally 3 counts = 1 degree but I think even 1 or 2 counts can pull 1 degree of timing. I'll let Tephra confirm that of course!
1-3 counts = 1 degree (minor knock, may not always occur in the same spot)
4-6 counts = 2 degrees
7-9 counts = 3 degrees
10+ counts = correct the knock ASAP!
I think usually 1-2 counts occasionally is livable, especially if pulling 1 degree of timing doesn't seem to clear it up at all. I have a TurboXS Knocklite and on it's most sensitive setting it won't trigger unless I hit 7+ counts. I can make it more sensitive by not revving it as high when I calibrate it for my base engine noise but I would rather only see it when it is definite knock.
Old Jun 2, 2009 | 07:39 PM
  #41
tephra's Avatar
yeah same is IX, so 3 KS = -1*
So 1KS = 0.35 timing retard.
You might see -1* with 2KS because of rounding etc..
Old Jun 2, 2009 | 07:56 PM
  #42
Bob_tm's Avatar
I will test log on 53040007 in two days.
Old Jun 2, 2009 | 09:09 PM
  #43
SiC's Avatar
SiC
Tephra, is the program you uploaded strictly for the 52680015 or can it be used with other ROM IDs too?
Old Jun 2, 2009 | 09:40 PM
  #44
tephra's Avatar
Any ROMID...
The XML changes allow the program to execute Mode23 commands.
The config file tells the program which memory addresses to retrieve.
Old Jun 2, 2009 | 09:54 PM
  #45
tephra's Avatar
updated post #1 with some details.
still need to test the new version of the app on my car b4 posting (you can still use the zip off page#2 if you want)
new version just has some minor enhancements.. (like waiting for you to plug the OP2.0 cable in etc etc)
