Evo X Logging
Old Jun 2, 2009 | 09:56 PM
  #46
SiC's Avatar
SiC
Thanks, I'll test it out tonight
Old Jun 2, 2009 | 09:59 PM
  #47
tephra's Avatar
ok..
anyways - I was able to log TPS. But it only goes upto ~87%.
Whats the deal with that? Also how do I know if I am logging the real throttle position or the electronic controlled TPS?
Old Jun 2, 2009 | 10:01 PM
  #48
SiC's Avatar
SiC
All other loggers that I know of only go up to 87% too.
Old Jun 3, 2009 | 12:11 AM
  #49
tephra's Avatar
ok guys.
I just tried this on a Cobb "enabled" ROM, and it doesn't work.
Cobb have had a similar idea to get logging out - But different.
I am not sure what they are trying todo yet - but as a precautionary note - I wouldn't try this mod on a Cobb ROM
Yeah - Note to Cobb - check your code there guys it's a bit dodgy - I am surprised its working...
Old Jun 3, 2009 | 01:53 AM
  #50
SiC's Avatar
SiC
I just tested it out on the 52360018, all I got was a bunch of jibberish for numbers.
*Edit, I guess I do have to edit the config.txt to my specific ROM. How do you know what each MUT address represents?
File Type: txt
Old Jun 3, 2009 | 04:32 AM
  #51
tephra's Avatar
its because there isn't a config file for 52360018 yet...
you need to find the memory addresses you want to log.
using the MUT_TABLE is a good starting point as they are universal - ie MUT06 = timingadvance, so whatever memory address is at MUT06 then you can use that in the config.txt
Old Jun 3, 2009 | 04:49 AM
  #52
SiC's Avatar
SiC
Yeah, I understand that but I was wondering how do you know what each MUT represents? Such as MUT06 = Timingadvance, is there a chart that tells what each MUT is? I can find the address as long as I know what each MUT is.
*Edit* Nevermind, I found it
Thanks,
SiC
Old Jun 3, 2009 | 04:50 AM
  #53
Hiboost's Avatar
ok..
Apparently that is normal, maybe 88% is absolute max that I've seen from any OBD2 logger I've tried.
Old Jun 3, 2009 | 08:13 AM
  #54
LaXGSR's Avatar
Tephra, does injector pulse width seem a bit high to you? I'm peaking at 20 ms, and your graph seems to peak at about 17 ms. Is this correct? Thanks!
Old Jun 3, 2009 | 10:47 AM
  #55
MR. Tim's Avatar
In to read about Tephrascan later . Thanks for the work and contributions to the community.
Old Jun 3, 2009 | 12:55 PM
  #56
GST Motorsports's Avatar
Need to know what RPM it is 20 ms at
Old Jun 3, 2009 | 01:01 PM
  #57
goofygrin's Avatar
ok guys.
This is soooooooo surprising to hear!
(do that in your head in a Homer Simpson voice)
Old Jun 3, 2009 | 01:03 PM
  #58
goofygrin's Avatar
I've got logs of peaks higher than 20 (21.25 @ 4700rpm, 22.53 @ 3842rpm).
Old Jun 3, 2009 | 01:11 PM
  #59
3842 is 72.13% IDC
4700 is 83.23% IDC
That does seem wrong.
Old Jun 3, 2009 | 01:20 PM
  #60
LaXGSR's Avatar
I tend to see 20 ms between 4000-4500 rpm's in third gear (GSR stock). I posted my log last night if you're interested (see ThirdGearGSRStock.txt).
If I understand the formula correctly, Injector Duty Cycle = Injector Pulse Width * RPM / 1200. So I have around 75% IDC at 4500 rpm's with 91 octane, stock GSR. Does that seem right?
