Evo X Logging
Old Jun 3, 2009 | 01:46 PM
  #61
goofygrin's Avatar
Originally Posted by GST Motorsports
3842 is 72.13% IDC
4700 is 83.23% IDC
That does seem wrong.
See the post above the one you replied to and you might see why
Old Jun 3, 2009 | 03:00 PM
  #62
TTP Engineering's Avatar
Originally Posted by tephra
ok guys.
I just tried this on a Cobb "enabled" ROM, and it doesn't work.
Cobb have had a similar idea to get logging out - But different.
I am not sure what they are trying todo yet - but as a precautionary note - I wouldn't try this mod on a Cobb ROM
Yeah - Note to Cobb - check your code there guys it's a bit dodgy - I am surprised its working...
So much for datalogging Evoscan for Cobb AP users.
Old Jun 3, 2009 | 06:19 PM
  #63
tephra's Avatar
Version 1.1 uploaded.
I also uploaded a fairly up to date version of my config.txt.
Old Jun 3, 2009 | 07:41 PM
  #64
TravisF's Avatar
Hey tephra I flashed the changes to my ecu but I can't get your program to run. It gives the error "This application has failed to start because the application configuration is incorrect" as soon as I try to run it. Do I need to copy some DLL files or install something else?
Thanks!
Old Jun 3, 2009 | 07:44 PM
  #65
tephra's Avatar
using 1.1?
what OS do you have? xp/vista/32/64?
Old Jun 3, 2009 | 07:49 PM
  #66
TravisF's Avatar
using 1.1?
I tried the original one you posted and the newer 1.1. I'm using XP 32-bit. I think I need newer msvcrt.dll files - I only have 8.0 and I think I need 9.0?
Old Jun 3, 2009 | 07:52 PM
  #67
tephra's Avatar
Ive uploaded a new version (1.1a) - can you try it?
Old Jun 3, 2009 | 07:54 PM
  #68
TravisF's Avatar
It works! I need to plug in my OP cable and get a quick log. Thanks!
Old Jun 3, 2009 | 07:55 PM
  #69
tephra's Avatar
Cool.
I think that's a new world record in terms of bug report to bug fix time
Old Jun 3, 2009 | 08:18 PM
  #70
SiC's Avatar
SiC
I just got done making the config for the JDM and noticed you updated your first post. I confirmed that the AUSDM is exactly the same for JDM 52360016-52370024, so you can add that to your first post
Old Jun 3, 2009 | 08:48 PM
  #71
tephra's Avatar
Yeh i've updated the 1st post with more config.txt's
I have included fuel trims (MUT0C and MUT0D), and made them log every 20 loops..
ok let me know how it goes guys
Old Jun 3, 2009 | 09:55 PM
  #72
TravisF's Avatar
Just did three third gear pulls (not the greatest on my part but got some data!). The fuel trim colums are jumping from 0 to -8.79 and -0.98. The speed doesn't seem right in the third log (158mph in third gear!?) but it looks ok in the first two.
File Type: txt
File Type: txt
File Type: txt
Old Jun 3, 2009 | 10:01 PM
  #73
tephra's Avatar
km/h
what romid - ill dbl check the trims
Old Jun 3, 2009 | 10:06 PM
  #74
tephra's Avatar
maybe MUT0C and MUT0D are not longer fuel trims?!?!
Old Jun 3, 2009 | 10:12 PM
  #75
TravisF's Avatar
Using rom 52680018. And km/h makes more sense, should have known
