Evo X Logging
Old Jun 20, 2009 | 11:33 AM
  #436
Mellon Racing's Avatar
Originally Posted by Hiboost
I tried on my friend's Evo 9 and had no luck either... I ended up going back to a restore point and reloading the software to get it working on my Evo X again. Also if you get a crash, you can remove the USB connection, wait a few seconds for the confirmation sound, then re-insert and launch EvoScan again and it will connect for me but I used to have to do a full reboot. If it crashes once it won't work again until you get the OpenPort 2.0 device to recognize properly in the OS.
I'm assuming that when you guys are connecting to older cars that you are using the little pigtail adapter that has a mini stereo jack looking connector in addition to the OBD2 style Tactrix cable?
yes, I'm using the second connector on the cable for the 8/9 cars.
  #437
the local x owner is going to try his laptop and his own cable to see if we can narrow down the culprit
Old Jun 20, 2009 | 01:38 PM
  #438
Hiboost's Avatar
Originally Posted by LaXGSR
I've have occasional issues where no matter what, it just stops reading. The first time I ended up uninstalling evoscan and ecuflash, then reinstalling ecuflash followed by evoscan. The second time, I just restarted my computer, and it magically started working again. Something seems a little flaky with the OpenPort 2.0 drivers at least on my winxp laptop.
Same here, I used to do a full reboot, now removing the USB and putting it back in "usually" makes it come alive again. It's hard to say what triggers it, although USB is nice I really don't like the loose nature of the USB plug design compared to a 9 pin serial cable that screws in. Perhaps some more development in the signal recovery programming should be looked into instead of having to manually reset it when it locks up EvoScan. Since it has never locked up in EcuFlash then likely the issue is OpenPort 2.0 drivers meshing with EvoScan but I have no proof.
Good deal, just wanted to cover all the bases!
Old Jun 20, 2009 | 02:28 PM
  #439
goofygrin's Avatar
I had an instance where I closed EvoScan while logging and it killed the OP2.0 cable. I had to disconnect it from the car and the computer, reboot, restart the car and rehook everything back up in order to get it to communicate again. Even EcuFlash wouldn't talk with it.
I don't think it's and EvoScan thing... but when the program closes, it should free up all it's resources (cable, etc.) so that this works a little smoother.
Old Jun 20, 2009 | 02:49 PM
  #440
GTR2009's Avatar
is it possible that the mode23 patch for rom have a different address for my 52680017 rom id? because the patch for 5268001xx seems that does not work on my evo
Old Jun 20, 2009 | 03:06 PM
  #441
jrsimon27's Avatar
has anybody in here whom has succesfully log there evos used the log in dataloglab?
i have the evoscan2.5version an iam about to buy the 2.0open port cable is all this 2 things what i need to log my stock evo x?
thanks
Old Jun 20, 2009 | 04:17 PM
  #442
evo4mad's Avatar
21st June 2009: EvoScan v2.6 Beta15.zip (see post #1 for download details)
- You still need to install EvoScan v2.5 full registered version first. Available here.
- Updated US and JAP/EU EvoX Mode23 items in data.xml.
- Updated graphing scales in data.xml for EvoX logging.
- CAN logging speed increased.
- Dataitem Editor fixed and now enabled.
- Vista64bit checking, and automatic folder permission setting for Vista.
Work in Progress:
- EvoX CAN formulas work in progress for full release this week.
- EvoX Read DTC and ClearDTC - work in progress.
- EvoX Transmission datalogging - work in Progress.
Old Jun 20, 2009 | 04:34 PM
  #443
SiC's Avatar
SiC
Originally Posted by jason4656
thanks for that do you or does anyone have a clean version of 0018 and the xml ? i already mapped and dynod my car but i can copy the tables over
am i wrong in thinking that 0018 inherits from 0016 therefore the 3 lines of xml would still go into 0016 rom file? or is there a full separate xml for the 0018 rom?
thanks for your help
52360018 does not inherit 52360016, PM me your email address and I'll send you the xml & clean ROM.
Old Jun 20, 2009 | 05:43 PM
  #444
tsitalon1's Avatar
Work in Progress:
Hamish,
I am astonished at your dedictaion to EvoScan, I have never seen development work happen this fast.
I don't know what your "real" job is but I'm sure they are not paying you enough
Thank you again for all your work...That goes for all involved as well..Sic, Gunzo, etc...
Old Jun 21, 2009 | 12:01 AM
  #445
GST Motorsports's Avatar
yes I was just going to make a post about this. I have DataLogLab and all the Mode23 stuff working great now.
I'm pretty happy with how everything is now.
Now we just need more items loggable, like grams/sec and/or lb/min, boost error, etc etc.
I'll post some screenshots of Evo 10 logs in DataLogLab tomorrow.
- Bryan
Old Jun 21, 2009 | 12:03 AM
  #446
jrsimon27's Avatar
- Bryan
great thanks for the info.
Old Jun 21, 2009 | 12:20 AM
  #447
evo4mad's Avatar
Originally Posted by SiC
^ Yes, it'll already work with the JDM 5236 & 5237 series without touching the Data.xml
SiC do you have an xml for 5237 series? I tried your 5236 but that is far different.
Old Jun 21, 2009 | 12:27 AM
  #448
evo4mad's Avatar
I don't think it's an EvoScan thing... but when the program closes, it should free up all it's resources (cable, etc.) so that this works a little smoother.
Yeah the op2.0 cable uses old ComPort technology and is flakey at the best of times. I too have seen OpenPort2.0 cable bluescreen my pc and also have seen it not tidy up resources if I end task software that has a connection open to the openport2.0. The Openport 1.3U doesn't have any of these problems.
Old Jun 21, 2009 | 01:03 AM
  #449
SiC's Avatar
SiC
Yes, I'll send it to you on MSN.
Old Jun 21, 2009 | 07:20 AM
  #450
mrfred's Avatar
- Bryan
Anything besides thos two items?
