Evo X Logging
Old Jul 20, 2009 | 10:57 PM
  #586
evo4mad's Avatar
Originally Posted by nj1266
Your formula worked I cross checked it with PCMScan lb/min logs and they are identical.
I have added your formula to the xml file provided by mrfred
what is the formula? can you send me the xml file too?
Old Jul 21, 2009 | 12:46 AM
  #587
tephra's Avatar
54060007 and 54070007 XML added in 1st post
Old Jul 21, 2009 | 12:47 AM
  #588
tephra's Avatar
Hamish - I had a good idea for evoscan.
Why not query the ROMID (as a mode23 request) and then just load up the right XML/Dataitems list depending on that query.
Then users dont have to do anything except get latest version of evoscan and do the mode23 mod...
Old Jul 21, 2009 | 01:25 AM
  #589
SiC's Avatar
SiC
I actually had Hamish make it possible to select different EvoX models. What you need to do is seperate the EvoX into different names such as EVOX08J, EVOX09J, EVOX08U, etc. on the XML. Then on the pulldown you will be able to select which EVOX you would like to log. This way you wont have a huge list of categories to log which include JDM & USDM.
When you do this, make sure you have the word "EVOX" in the name since it picks up this word.
Old Jul 21, 2009 | 07:45 AM
  #590
LaXGSR's Avatar
Glad it worked, and thanks for verifying with PCMScan that it's right. And thanks tephra for figuring out the address and scaling Just curious, have you logged airflow on a stock or close to stock car? What is the max lb/min you typically see?
Hamish, here is the formula for airflow on USDM GSR 52680018:
<DataListItem DataLog="N" Color="" Display="Mode23 Airflow" LogReference="Mode23Airflow" RequestID="238087e0" Eval="x*0.002646" Unit="lb/min" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="50" ChartMin="0" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Jul 21, 2009 | 08:53 AM
  #591
evo4mad's Avatar
yep I added these with g/s and lb/min. what vehicles do they associate with? the options are:
1) "Mode23 2008 JDM EVOX"
2) "Mode23 2009 JDM EVOX"
3) "Mode23 USA EVOX"
<DataListItem DataLog="N" Color="" Display="Mode23 Airflow 530400xx" LogReference="Mode23Airflow530400xx" RequestID="238087D8" Eval="x*0.002646" Unit="lb/min" MetricEval="x*2/100" MetricUnit="g/s" ResponseBytes="2" GaugeMin="0" GaugeMax="50" ChartMin="0" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mode23 Airflow 526800xx" LogReference="Mode23Airflow526800xx" RequestID="238087E0" Eval="x*0.002646" Unit="lb/min" MetricEval="x*2/100" MetricUnit="g/s" ResponseBytes="2" GaugeMin="0" GaugeMax="50" ChartMin="0" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Jul 21, 2009 | 10:04 AM
  #592
criptballer's Avatar
does this mean there is going to be another beta soon hamish?
Old Jul 21, 2009 | 10:24 AM
  #593
LaXGSR's Avatar
I'm not sure about the others, but Mode23Airflow526800xx is the "Mode 23 USA Evo X".
Old Jul 21, 2009 | 11:16 AM
  #594
nj1266's Avatar
On a stock untuned Evo X the airflow is 33 lb/min @ 7000 rpm. I have logged two stock ones so far and they are both @ 33 lb/min.
Old Jul 21, 2009 | 01:31 PM
  #595
evo4mad's Avatar
thanks to RPW performance I now have an etacs and efi CAN ecu. now I just need to locate an Evo9 ecu, and I will have the full range of Mitsubishi ecus. anyone seen some evo9 efi ecus for sale?
Old Jul 21, 2009 | 02:14 PM
  #596
onboost's Avatar
il have search for you tonight i have nothing else to do lol
Old Jul 21, 2009 | 03:55 PM
  #597
evo4mad's Avatar
awesome, thanks onboost.
Old Jul 21, 2009 | 04:26 PM
  #598
tephra's Avatar
stock airflow is 265 g/s - dunno what lb/min that is
hamish the 530400xx is AUDM X GSR
Old Jul 23, 2009 | 12:45 AM
  #599
tobz's Avatar
I have a 9 ecu sitting around the shop i dont need. PM me.
Old Jul 24, 2009 | 08:41 AM
  #600
voltexct9a's Avatar
anyone has the xml edit i need to do for 52350016 ? jdm evo x rs 2008 model
so i just edit the xml and run the .exe file in the .zip?
