Evo X Logging
Old Jul 15, 2009 | 01:55 PM
  #541
nj1266's Avatar
Originally Posted by tephra
As posted in the other thread:
MAF airflow in g/s:
530400xx: 0x8087d8 (2byte)
526800xx: 0x8087e0 (2byte)
Formula is x * 2 / 100
Tephra or mrfred
Do you have the complete code in lb/min to include this in Evoscan mode 23? This is for the USDM models.
Thanks
PS: I want to thank you both for mode23 logging. It works like a charm. I have stopped using my beloved PCMScan to tune Evo Xs
  #542
nj1266's Avatar
Evo4mad PLEASE fix the LM-1 wideband glitch in Evoscan ver 2.5/2.6. Everytime I lift off the gas for an extended period of time the LM-1 logging via Evoscan stops and never comes back. I have to re-start the log to get it to work again. I have told you about this a long time ago. I am currently logging with ZT2 and I prefer to log with the LM-1.
Old Jul 15, 2009 | 04:05 PM
  #543
LaXGSR's Avatar
Originally Posted by nj1266
Tephra or mrfred
Thanks
The conversion from g/s to lb/min is 0.1323, so just multiply by that in the formula. Or to simplify, just use x * 0.002646 to get airflow in lb/min. I'd be very curious to see how much airflow you are logging just to double check it's the right formula.
Old Jul 15, 2009 | 06:59 PM
  #544
nj1266's Avatar
Do you have the FULL code that needs to be entered in the xml file? I do not know what to put in the xml file.
For example the formula for timing is this
<DataListItem DataLog="N" Color="" Display="Mode23 TimingAdv" LogReference="Mode23TimingAdv" RequestID="23808a07" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="50" ChartMin="-15" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
What would the formula for airflow in lb/min be?
Thanks
Old Jul 16, 2009 | 08:08 AM
  #545
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
MUT initialization in CT9A returns 4 bytes:
0x00 0x55 0xEF 0x85
MUT init reply bytes' locations in 53040010:
0000E300 ECHO_REPLY 0x00 - presumably
00040F84 Sync word 0x55
00040FC4 KeyWord #1 0xEF
00041034 KeyWord #2 0x85
so whole trick to get MUT communication is hidden in this code
Code:
00040D3C                 lduh    R0, @((pin83_changing_counter - unk_80C000), fp)
00040D40                 cmp     R1, R1
00040D42                 ldi8    R1, #1
00040D44                 subx    R0, R1          ; r0 = r0 - 1 - C
00040D44                                         ; C = 1 if r0 < 0
00040D46                 bc.s    loc_40D8C
00040D48                 subx    R0, R1
00040D4A                 bc.s    loc_40DD0
00040D4C                 subx    R0, R1
00040D4E                 bc.s    loc_40DFC
00040D50                 subx    R0, R1 || nop
00040D54                 bc.l    loc_40F84
00040D58                 subx    R0, R1 || nop
00040D5C                 bc.l    loc_40FB0
00040D60                 subx    R0, R1 || nop
00040D64                 bc.l    loc_40FBC
00040D68                 subx    R0, R1 || nop
00040D6C                 bc.l    loc_40FFC
00040D70                 subx    R0, R1 || nop
00040D74                 bc.l    loc_41010
00040D78                 subx    R0, R1 || nop
00040D7C                 bc.l    loc_41080
00040D80                 subx    R0, R1 || nop
00040D84                 bc.l    loc_410B0
00040D88                 bra.l   set_808c7c_to_0
Now who will be the first to sort/try it out?
I bet on tephra, but hamish is my second candidate
Old Jul 16, 2009 | 08:23 AM
  #546
LaXGSR's Avatar
Thanks
Here ya go...let me know how this works:
<DataListItem DataLog="N" Color="" Display="Mode23 Airflow" LogReference="Mode23Airflow" RequestID="238087e0" Eval="x*0.002646" Unit="lb/min" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="50" ChartMin="0" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Jul 16, 2009 | 12:05 PM
  #547
nj1266's Avatar
Thank you sir for your help.
Old Jul 16, 2009 | 03:40 PM
  #548
LaXGSR's Avatar
No prob! Hope you get some good results...
Old Jul 16, 2009 | 04:20 PM
  #549
tephra's Avatar
acamus - yeah I couldn't work that init code out...
Old Jul 16, 2009 | 09:58 PM
  #550
acamus's Avatar
I do not know what edge detection is used raising/falling or both?
Presuming that changing counter is what the name is saying and only one side edge detection,
one has to send 0xAA 0xAA 0xAA 0xAA 0xAA, in order to get to the last line of above code.
So init reply shall look like 0xAA 0x55 0xEF 0x85.
What line is pin83 actually OBD PIN 7 or OBD PIN 8?
Unfortunately I do not have the ECU to play with, it is based only on disassy.
Old Jul 16, 2009 | 10:18 PM
  #551
tephra's Avatar
K-Line
Old Jul 16, 2009 | 10:43 PM
  #552
acamus's Avatar
If I would have the ECU, I would write application that is sending init codes 0xYY running from 00-FF, and observe the reply,
once I would get 0xYY 0x55 0xEF 0x85 reply that would be the init code.
Btw. I know we have the solution already, but I am trying to find the clean solution, working without Mode23 patch.
Old Jul 16, 2009 | 10:47 PM
  #553
tephra's Avatar
yes Hamish tried that...
I actually think the "reflash" pin needs to be enabled for some advanced debuging (read mode23, reflashing, serial MUT, etc)...
Old Jul 16, 2009 | 10:53 PM
  #554
acamus's Avatar
Tephra, you know we are so close, it is only one step to get it working,
I have been looking at the MUT code, it is exactly same just built for different processor.
Have you found variable that holds the L-line, reflash,
does it appear in that init routine?
Old Jul 16, 2009 | 10:57 PM
  #555
tephra's Avatar
I don't think its "L-Line"
If you trace back the mode23 stuff you will see it requires OBD-Debug (Mode0x10) to be set first.
AND then ontop it requires something else to be set, this can be traced back to a I/O pin - I think its in my disasm I sent you...
Trouble is I can't set a voltage on OBD PIN8 (the only other pin hooked to the ECU) because OBD Pin8 isn't a valid choice in J2345... weird!
