Evo X Logging
Old Jul 5, 2009 | 01:09 PM
  #511
nj1266's Avatar
I tried logging mode23 today and it did not work. I have Evoscan v2.6beta installed and I am using mrfred's latest xml file posted in this thread. The ECU is flashed with the correct code.
I kept getting the following error code:
Error: Conversion from string "&HLC" to type 'integer' is not valid.
I tried with WDBO2 enabled and disabled and got the same result. I tried with "mode23 mod only below here" checked and unchecked and still got the same results.
When I swapped back to my CAN xml file, the logger worked.
What am I doing wrong?
Old Jul 5, 2009 | 08:37 PM
  #512
mrfred's Avatar
This is covered in the previous page or the page before that.
Old Jul 6, 2009 | 06:12 PM
  #513
nj1266's Avatar
Thanks mrfred.
I do have some questions. Does the TBEC table add/subtract WGDC to the passive or reactive solenoid? Is there a third load to be logged for the boost? I know we can log the timing and fuel load, but is there one for the boost?
Old Jul 6, 2009 | 06:28 PM
  #514
tephra's Avatar
the passive solenoid is.... passive
hehe
Old Jul 6, 2009 | 06:40 PM
  #515
SiC's Avatar
SiC
tephra, have you found the intake & exhaust VVT degrees?
Old Jul 6, 2009 | 06:56 PM
  #516
gunzo's Avatar
Max is 25 intake variation and 35 exhaust ..
Old Jul 6, 2009 | 07:00 PM
  #517
SiC's Avatar
SiC
Yeah, 10-35* for intake and is exhaust +10 to -25*? I was trying to figure this out that's why I wanted to log the VVT degrees.
  #518
tephra's Avatar
no - funny you should ask, I was looking for them yesterday !
Old Jul 6, 2009 | 07:03 PM
  #519
gunzo's Avatar
Hmm .. thought I passed them to you ?? .. they are correct you know
it's 10-35 intake opening referenced BTDC
0-35 exhaust closing referenced ATDC
Old Jul 6, 2009 | 07:40 PM
  #520
SiC's Avatar
SiC
Okay, I think the formulas may be off, I'm seeing -12* (peak load WOT) to +21* (idle) for intake.
Old Jul 6, 2009 | 07:45 PM
  #521
gunzo's Avatar
2byte ???
ok .. I'll go check and pm you
Old Jul 6, 2009 | 07:54 PM
  #522
SiC's Avatar
SiC
2byte ???
Yes, 2byte
Old Jul 6, 2009 | 11:03 PM
  #523
nj1266's Avatar
hehe
So you are saying that WGDCC changes are based off of the reactive solenoid that is maxxed out at 100% at WOT unless you are running a pill? So how does the WGDCC react or correct when the reactive solenoid is at 100%? Have you logged it? Can you post the log of passive and reactive solenoids and WGDCC during a WOT run?
Old Jul 6, 2009 | 11:19 PM
  #524
GST Motorsports's Avatar
It pulls from the reactive solenoid if needed. I've seen it in logs. The passive solenoid is a odd feature.
When still using both solenoids and bigger turbos you can have the passive set at 0 and reactive set at a certain %. The curve will not be "full" like a single solenoid until you start using the passive solenoid %.
Old Jul 7, 2009 | 09:00 PM
  #525
tephra's Avatar
I have discovered that the ECU uses the following scaling for the OBD_MAP signal (ie mode1 pid 0xb)
kpa = adc_map * 1.345 + 0.25
the ECU also caps this at 255kpa (as per the standard )
