Evo X Logging
Old Jul 26, 2009 | 04:02 AM
  #616
Mellon Racing's Avatar
Originally Posted by nj1266
Hamish,
Did you fix the glitch while logging the AFR from an LM-1? As I told you a long time ago, when logging the LM-1 through Evoscan and you lift off the gas, Evoscan cuts off the LM-1 and it never comes back again. The user must stop logging and start logging again to enable Evoscan to log the LM-1.
This has been going on since version 2.4 of Evoscan. Have you fixed it? Please fix it if you have not. I am forced to log AFR wit the ZT2 and I do not like the ZT2. Please Hamish, fix this glitch. There are a lot of LM-1 users who have this problem.
that's interesting, I have a customer with a LM-1 and we didn't have any problems, I wonder why it would be different for us. We aren't using any of the mode23 stuff yet, keeping it simple. Maybe one of the paremeters you're trying to log is causing a problem. We're using "external wb02" in particular and I see some other "wb02" paremeters
Old Jul 26, 2009 | 11:53 AM
  #617
xbox4414's Avatar
Originally Posted by GST Motorsports
Those are screenshots from Innovate LogWorks software
LOL that makes sense now. Well I know in PCMScan you could make tables like that. Does EvoScan have that option? IDK what it is but I find the graphs in EvoScan to be more confusing than say in PCMScan...do I need to set up the graphs or are the configured when the program is first installed?
Old Jul 26, 2009 | 11:56 AM
  #618
GST Motorsports's Avatar
Yes evoscan can be configured to give you those traced cell graphs if that is what you are after.
If you are looking for visualized plot graphs, I've found DataLogLab is hard to beat.
Old Jul 26, 2009 | 12:05 PM
  #619
xbox4414's Avatar
How do you have EvoScan configured? Graphs or these traced cell graphs? I'm trying to figure out the best way to read a log in EvoScan....
Old Jul 26, 2009 | 12:26 PM
  #620
Kooldino's Avatar
Just getting this set up now...I read the ROM from my ECU via EcuFlash - It wasn't clear, but I'm guessing the ROM ID everyone is talking about is found under ROM INFO>Internal ID? The result there is 52680018 on this car. ECU ID was blank.
Is there a manual out there for this stuff? I checked the wiki on openecu.org but didn't find much in terms of getting this all set up.
Old Jul 26, 2009 | 12:36 PM
  #621
tokeone's Avatar
kooldino - you are correct.
i have a graph question also. you cant graph if you have a modified data xml right?
i have the one that sic posted and the one the mrfred posted (which is nice cause its only using mode23 stuff)
but i cant graph with the mrfred data xml correct?
Old Jul 26, 2009 | 12:49 PM
  #622
Kooldino's Avatar
Ok, cool. I'm currently editing my XML file located at C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Now when I add the mode 23 stuff to the XML file, do I have to add it in a specific place? I didn't see any mention of it i the first post.
Would inserting it here help?
Code:
<rom>
    <romid>
        <xmlid>52680018</xmlid>
        <internalidaddress>5002A</internalidaddress>
        <internalidhex>52680018</internalidhex>
        <make>Mitsubishi</make>
        <market>USDM</market>
        <model>Lancer</model>
        <submodel>Evolution X</submodel>
        <transmission>5MT</transmission>
        <year>2008</year>
        <flashmethod>mitsucan</flashmethod>
        <checksummodule>mitsucan</checksummodule>
        <memmodel>M32186F8</memmodel>
    </romid>
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f58d" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ada5" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8adaa" scaling="Hex16"/>
    <include>52680015</include>
</rom>
PS - the last ">" is missing in the 52680015 snipped in the first post.
Old Jul 26, 2009 | 01:04 PM
  #623
tokeone's Avatar
ok, before you do anything save your stock ecu setting as a .hex so that you have it
im a noob and i got mine from someone else
but its at the bottom under **misc**
Old Jul 26, 2009 | 01:23 PM
  #624
Kooldino's Avatar
This isn't doing anything. I have no options under MISC except for ECU ID. Here's what I did:
1) downloaded my rom using ecuflash
2) Found the ROM ID
3) used the ROM ID add the 3 XML lines in Tephra's post above to the ROM meta data located at: C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ 52680018.xml
4) opened up the ROM I downloaded in step 1 with ecu flash
Old Jul 26, 2009 | 01:49 PM
  #625
tokeone's Avatar
kooldino - i sent you a pm.
i hope this isnt the blind leading the blind but i had someone show me how to do it thursday, so its all still fresh in my mind.
Old Jul 26, 2009 | 03:16 PM
  #626
Kooldino's Avatar
I just tried some logs for practice with EvoScan and found something odd. If I go to "C:\Program Files\EvoScan\EvoScan v2.6 Beta17\SavedDataLogs" I will only see two sample logs.
However, if I go to "Graphs & Maptracer>Analyze .csv", I will get a list of the same exact directory (I verified it was the same) with the two sample logs PLUS all of the logs that I've taken.
What the hell?
Edit - I ended up finding them in "C:\Users\Dino\AppData\Local\VirtualStore\Prog ram Files\EvoScan\EvoScan v2.6 Beta17\SavedDataLogs"
I guess this is some kind of Vista thing? The original default "C:\Program Files\EvoScan\EvoScan v2.6 Beta17\SavedDataLogs" does exist, but it's not being used. Don't ask me why.
Old Jul 26, 2009 | 04:33 PM
  #627
Kooldino's Avatar
Is there a list of things that Mode23 will allow you to log that you couldn't normally?
I was told that to log knock count, I had to enable mode 23, but that doesn't seem to be the case. I suspect that you might have to do this to log knock retard, since it always shows a value of 255 as it site right now in beta 17.
Old Jul 26, 2009 | 04:36 PM
  #628
tokeone's Avatar
did you get it all figured out then?
Old Jul 26, 2009 | 06:25 PM
  #629
Kooldino's Avatar
What the hell?
Ok, things just got one stage weirder. I didn't change anything in EvoScan. I went out and did some more logs, and this time, it stored the logs in "C:\Program Files\EvoScan\EvoScan v2.6 Beta17\SavedDataLogs". The really crazy part is that if I go to "Graphs & Maptracer>Analyze .csv", it seems to list the contents of both folders as if there is one folder that contains them all. Very odd. Anyone have any input on that one?
  #630
Kooldino's Avatar
Not the mode23 stuff.
