Evo X Logging
Old Jul 27, 2009 | 05:04 PM
  #646
Noize's Avatar
EvoM Administrator
OK, I am sorry to be an idiot, but I need help.
My ID is 52680018
I open my 52680018.xml with Notepad, and see this:
<rom>
<romid>
<xmlid>52680018</xmlid>
<internalidaddress>5002A</internalidaddress>
<internalidhex>52680018</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>Evolution X</submodel>
<transmission>5MT</transmission>
<year>2008</year>
<flashmethod>mitsucan</flashmethod>
<checksummodule>mitsucan</checksummodule>
<memmodel>M32186F8</memmodel>
</romid>
<include>52680015</include>
</rom>
So basically, I want to copy this data in, and it looks like this:
<rom>
<romid>
<year>2008</year>
</romid>
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
</rom>
Then I save it in Notepad and close. Correct?
I don't want to screw anything up. Thanks in advance.
Old Jul 27, 2009 | 05:12 PM
  #647
SiC's Avatar
SiC
Yes, that is correct
Then open your ROM up in ECUFlash and change the numbers 05 to 23, 05 to 23, and 42 to 52.
My ID is 52680018
<rom>
<romid>
<year>2008</year>
</romid>
</rom>
<rom>
<romid>
<year>2008</year>
</romid>
</rom>
Old Jul 27, 2009 | 05:13 PM
  #648
tokeone's Avatar
noize - did you check this out?
https://www.evolutionm.net/forums/ev...lustrated.html
someone correct me if i am wrong, but my understand is that you can make those changes to 52680015 (as shown in the tutorial) because in the 52680018 file it has the line
so essentially when it reads 52680018 its also pointing to 52680015
Old Jul 27, 2009 | 05:16 PM
  #649
SiC's Avatar
SiC
If you're only dealing with 52680018 then you can just edit that XML but if you want to deal with all 5268 series ROMs then you should edit the 52680015 XML.
Old Jul 27, 2009 | 05:18 PM
  #650
Excalibur's Avatar
This **** confuses the **** out of me.
Old Jul 27, 2009 | 05:44 PM
  #651
xbox4414's Avatar
Okay what's the difference between Mode23 logging and the regular Evo X ECU? Also what is the difference between 2-byte RPM and regular RPM?
Old Jul 27, 2009 | 05:48 PM
  #652
Noize's Avatar
EvoM Administrator
OK, but since the 52680015 looks exactly like the one in the illustrated thread, I can edit it there instead, yes?
Old Jul 27, 2009 | 05:52 PM
  #653
MR. Tim's Avatar
Yes because if you add it into 52680015, even if your rom is 52680018, you will still have the Mode 23 stuff because 52680016-20 all call 52680015.
Old Jul 27, 2009 | 05:55 PM
  #654
Mellon Racing's Avatar
I haven't jumped on the mode23 bandwagon, not having trouble tuning without it.
Old Jul 27, 2009 | 06:17 PM
  #655
LaXGSR's Avatar
Are you able to log load and boost through the ECU without mode23? I didn't think the CAN ID's worked yet?
Old Jul 27, 2009 | 06:56 PM
  #656
Kooldino's Avatar
When I added mine to 18 it wouldn't recognize it, but when I added it to 15 (which 18 inherits) it worked like a charm. Go figure.
Old Jul 27, 2009 | 07:05 PM
  #657
Noize's Avatar
EvoM Administrator
This works brilliantly.
Thank you, gentlemen!
Old Jul 27, 2009 | 07:10 PM
  #658
newcomer81's Avatar
has anyone else experienced this?
i am thinking about updating my how-to to explain about placing the XML nodes in the base metadata rather than the ID that matches your ROM ID
Old Jul 27, 2009 | 07:28 PM
  #659
Noize's Avatar
EvoM Administrator
I think you should, because mine was not working in 18, but works perfectly in 15. Its like logging a CT9A now.
Old Jul 27, 2009 | 08:06 PM
  #660
nj1266's Avatar
Originally Posted by evo4mad
25th July 2009: EvoScan v2.6 Beta17 released!
Download EvoScan Beta17 here(registered users only. Unregistered users get your registration number from www.evoscan.com)
- ADDED OBDII DATALOGGING SUPPORT for OpenPort1.3U and OpenPort 2.0
- this will work with ALL vehicles 1996-2008 (OBDII)
(the government should have mandated Generic OBDII be fast, lol! EvoScan makes it as fast as it can, its still a waste of time for Mitsubishi owners, stick with MUTII)
- Relabelled all the protocols and devices.
- More support for OpenPort 2.0 and Evo7/8/9 Actuators+DTC
- More support for 2008/09 JDM EvoX Mode23 (thanks SiC)
- More support for multiple
- Added a new checkbox to "Display only selected items" hides the dataitems you're not logging at that time.
Hamish,
I installed this version and tested how the LM-1 works with it. It is NOT cutting out when I lift off the gas. It works. The LM-1 works with version 17 on my Evo 9. YAY!!!!
Thanks Hamish for fixing this problem.
I still have to test mode23 logging on an Evo X with the LM-1 and see if it works.
Hamish, Logging an Evo X in mode 23 with the LM-1 should be the same as logging an Evo 9? Correct? The LM-1 will not cut off. Right?
