Evo X Logging
Old Sep 12, 2009 | 04:05 PM
  #766
Excalibur's Avatar
Just wish I had someone to call to talk me through it or something.
Old Sep 12, 2009 | 04:06 PM
  #767
xbox4414's Avatar
Got AIM? I'm on AIM..
Old Sep 12, 2009 | 04:24 PM
  #768
Excalibur's Avatar
You on skype? I can't share my screen with you if you would like.
Old Sep 13, 2009 | 05:34 PM
  #769
evo4mad's Avatar
EvoScan v2.7 Beta4
Map Tracer Fixes in v2.7 Beta4
- Download Here
- Now loads xml files rommetadata from ecuflash without relying on an old ecuflash path registry key
- Now loads 2 or levels of xml includes. (which was the case with USDM EvoX xml rommetadata files.)
- Now added the CAN OBDII data.xml file
- Now realtime graphing stays in Sync when ticking more dataitems.
Future Map Tracer suggestion improvements:
- Allow the map tracer to only display the selected range on the Line Graph.
- Allow support for Evo5 roms
If you wish to add to this improvements list, let me know.
Old Sep 19, 2009 | 09:33 AM
  #770
crcain's Avatar
Hamish thanks... I used beta19 last night and everything logged terrific for my friends JDM Evo X. I couldn't get it to work around when I was trying beta14 or so.
I have a question though.. could you give me an idea of what version to choose at this point? Also are all the 2.7 betas a full installer deal or are they a "unzip in a 2.7 installed folder"? Also, where can I find 2.6 final?
Thanks much. Loving the sampling rate with the Evo X + mode23. Thanks SiC as well for helping me with the mode23 addresses for the 5260016 rom which btw is not listed on the first post of this thread. Maybe it should be put there?
Old Sep 20, 2009 | 03:24 PM
  #771
Mellon Racing's Avatar
is there an option to set the log file location? would be handy to save it to the location where my customers rom is located.
Old Sep 20, 2009 | 03:56 PM
  #772
tephra's Avatar
for my logger?
no
just use evoscan - its got more bells and whistles than santas sled!
Old Sep 20, 2009 | 11:19 PM
  #773
funks's Avatar
Originally Posted by tephra
email me dude, we can exchange over email
Your e-mail address seems to elude me at the moment - lol. (and your PM is eternally full)..
Old Sep 20, 2009 | 11:23 PM
  #774
tephra's Avatar
it's <something>@gmail.com ...
i'll let u guess what the <something> bit is
Old Sep 25, 2009 | 11:50 PM
  #775
funks's Avatar
Thanks, e-mail sent.
Old Oct 1, 2009 | 02:26 PM
  #776
funks's Avatar
The MODE 23 EVOXLogger w/ Wideband based off Tephra's is alive. I'd like to thank Tephra for sharing the power of his source :]
It's not a straight C program anymore (now C++/CLI ), so it requires the .NET framework version 3.5 SP1
Wideband Currently Supported
"PLX" <-- definitely works (PLX SM-AFR)
"LM1" <-- needs testing.. (Innovate LM-1)
"LC1" <-- needs testing.. (Innovate LC-1)
"ZT2" <-- needs testing.. (Zeitronix ZT-2)
"AEM" <-- needs testing.. (AEM UEGO)
Monitors get configured as follows via file "monitors.config"
Code:
# Name:Source:HexAddress:ReturnBytes:RPNFormula:Priority
# 1) Make sure there are NO SPACES (including @ end)
# 2) Make sure your formula is correct - "x" is the value returned from the car.
TPS:OP2:0x8086F9:1:x,32,-,129,*,255,/:1
2ByteRPM:OP2:0x808746:2:x,3.90625,*:1
LoadFuel:OP2:0x80876E:2:x,10,*,32,/:1
LoadMivec:OP2:0x808774:2:x,10,*,32,/:1
TimingAdv:OP2:0x808A07:1:x,20,-:1
KnockSum:OP2:0x808A4B:1:x:1
PSIG:OP2:0x80871A:2:x,4,/,0.19347,*,14.5,-:1
WideBandAF:WB:0x000000:0:x:1
The wideband stuff like this via file "wb.config"
Code:
# Type:COMPORT:TestMode
PLX:COM4:false
When you run the "evoxlogger.exe" it automatically creates a log file in the relative "logs" folder..
The autogenerated filename is generated with the following format - example: "EVOXLoggerDataLog-2009_10_01-22_58.csv"
If you run it as such "evoxlogger.exe C:\temp\mylog.csv" then it writes to the file file path passed in..
Old Oct 1, 2009 | 09:18 PM
  #777
funks's Avatar
It's alive!
Sample Log attached
Does this look right?
Old Oct 2, 2009 | 06:01 PM
  #778
GST Motorsports's Avatar
Tephra,
Anyway you can find mode 23 for Rom ID: 53610010
AUS 09 Lancer Ralliart rom
You can grab it here:
https://www.evolutionm.net/forums/7570511-post263.html
53600010 mode23 XML shows wrong in this rom.
Thanks!
Old Oct 2, 2009 | 06:17 PM
  #779
tephra's Avatar
hey Bryan - I will take a look when I have time
Old Oct 2, 2009 | 06:21 PM
  #780
Thanks! No rush
