Evo X Logging
Old Dec 23, 2012 | 05:59 PM
  #1111
richardjh's Avatar
Yeah, sorry... as discussed via pm, my mistake.
Rich
Old Dec 30, 2012 | 07:28 PM
  #1112
salt36's Avatar
Is there a way to tell if I am logging the knock sum correctly ?
I am seeing knock counts up to 11 at highway cruise, although the ECU does not pull the timing until the count is over 10....
WOT runs see knock count up to 13-14 and the ECU will pull 2 degrees then.
Actually I just realized this started after I upgraded the Openport to the latest firmware with EcuFlash 1.44.3719
Before the knock count was up to 3 on a WOT run....
Strangely enough there is a couple of cruise logs that show no knock, after the firmware upgrade.
I'm confused
Old May 22, 2013 | 06:21 AM
  #1113
ithinku's Avatar
This is great stuff
Tephra can you help out with an XML for 52510010
Old Jan 2, 2014 | 07:35 AM
  #1114
Rico8638's Avatar
Hello Sir
Do you have the xml file for 52510010?
Old Jan 2, 2014 | 07:37 AM
  #1115
Rico8638's Avatar
Originally Posted by ithinku
This is great stuff
Hello Sir
Do you have the .xml file for 52510010?
Old Feb 13, 2014 | 05:24 PM
  #1116
kaliney65's Avatar
unable to edit the mode 23 maps
Hello everyone. Im new to logging and I kept getting bad numbers from my log which has lead me to here. From what I understand you have to edit the mode 23 maps to get the correct number while logging. Im unable to edit the mode 23 maps in the misc section. I had the mode 23 maps already in my misc section before trying to edit the xml but when I tried to open them they said disabled. I followed the directions in the enable mode 23 thread and got to the point where your supposed to edit the map because they come up disabled.
When I went to edit the 52680015 xml and there was what seemed to be only part of the required text that was shown in step 5 of the how to thread. I saved the original xml of course to have a backup but I cannot get the mode 23 maps to come up anything other than disabled. I have tried to edit the mode 23 maps with the original txt that was in the xml which I will list below, both the original and the txt show to copy from step 5 for my rom 52680020, and with only the txt show to copy in step 5 for my specific rom. Am I doing something wrong here or what im confused. Does anybody have the xml for 52680020 that they have been able to use the mode 23 they can send me.
any help here would be great
original
<table name="Mode 23 - IFMode 0x05 -> 0x23 #1" address="7f121"/>
<table name="Mode 23 - IFMode 0x05 -> 0x23 #2" address="8ab11"/>
<table name="Mode 23 - DoMode 0x42 -> 0x52" address="8ab16"/>
Old Sep 5, 2014 | 12:33 PM
  #1117
ecktt's Avatar
original
I had the exact same issue yesterday until I added the addition entries.
Old Sep 5, 2014 | 12:39 PM
  #1118
ecktt's Avatar
on a side note my DoMode original value for a 52360018 ROM was 0x4242. I changed it to 0x52 anyway. all seems to work eventually.
Old Dec 2, 2014 | 12:45 PM
  #1119
John.'s Avatar
Good day!
A little over a year ago in Baltimore bought Evo X MR, some time later purchased on the official site
OpenPort 2.0, Evoscan 2.9.0023 (updated to 0092) and download EcuFlash 1.44.4247.
Until recently, I was in it nothing particularly worried, but a month after the removal of the catalyst and the competition in the Sich, I
there was a knock and pereduv.Now I try to remove the logs using Evoscan, pre-switching in the firmware in two mode23
places with 05 to 23 and in another with 4D to 5D, tried different versions of logging Evoscan, but he could not achieve
real evidence. Judging from the logs that can be controlled (speed, throttle, AFR and speed) - standing on the ground speed
Springs 400 miles, then a minus throttle, and then displays plus does not respond to pedal movement, the load is less then the value in thousands
displays, etc., respectively, the remaining logs testimony is also not valid and can not rely on them. Trying to find the Old forums,
but so far no useful information on removing logs found. Therefore, I decided to write my question is maximized and if
who knows how to set up Evoscan to remove the logs on the Evo X MR SST, ID 59590004 prshivki, please tell me.
Thanks in advance!
Yours Evgeniy!
I apologize if the translation is not quite correct.
Translated using Google translator.
Old Dec 2, 2014 | 03:11 PM
  #1120
ikt's Avatar
ikt
Originally Posted by John.
Good day!
Thanks in advance!
Yours Evgeniy!
It is good enough for google translate!
Try sending a private message to the user evoscan on here, that is the owner. If anyone will know, he will.
Old Dec 4, 2014 | 07:10 AM
  #1121
John.'s Avatar
On your advice, appealed for help to the user evoscan, waiting for an answer. I hope he will be able to tell.
Old Dec 5, 2014 | 09:37 PM
  #1122
phoenixforce's Avatar
I'm also trying to determine the correct memory locations and values to add to the XML file in ECUFlash to enable mode 23 so I can start logging. ECU ID 59590005, which I believe is the latest after the recall.
Old Dec 11, 2014 | 01:15 PM
  #1123
John.'s Avatar
User evoscan does not respond, the official website http://www.evoscan.com/ also not responding.
Really no one can tell me how to get the correct data when logging Evo X ECU ID 59590004?
Old Dec 11, 2014 | 01:55 PM
  #1124
RazorLab's Avatar
2013-2014 is the same for USDM. Use the 59590004 address and XML
Code:
<ecu name="Golden 2013 USDM v1 EVOX">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="23808798" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor=".01" Notes="High Resolution RPM" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AB45" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="2380876A" Eval="(x*0.0482435)-[Baro]" Unit="PSIG" MetricEval="x*0.3326271-[Baro]" MetricUnit="kPa" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="AFR" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="10" GaugeMax="16" ChartMin="10" ChartMax="16" ScalingFactor="1" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="238087C0" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A5B" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A9F" Eval="x*1.000001" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="23808749" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808BB7" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AB80" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAFCalcs" LogReference="MAFCalcs" RequestID="23808FDC" Eval="x*100/16384" Unit="Load" MetricEval="" MetricUnit="" ResponseBytes="4" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAPCalcs" LogReference="MAPCalcs" RequestID="2380880A" Eval="x*100/16384" Unit="Load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Load (MIVEC) and (Timing if IAT GT 75F)" LogReference="LoadMIVEC" RequestID="238087C6" Eval="x*10/32" Unit="Load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="340" ChartMin="0" ChartMax="340" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="WGDC Correction" LogReference="WGDCCorr" RequestID="23808BB5" Eval="0.5*x-64" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="23809645" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="238086A9" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808687" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="238086A3" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="2380883B" Eval="x*1.243" Unit="mph" MetricEval="x*2" MetricUnit="kph" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808FCC" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088EC" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088FD" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Air/Fuel Ratio (Map)" LogReference="AFRMAP" RequestID="23808949" Eval="(14.7*128)/x" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front O2" LogReference="FrontO2" RequestID="238086B5" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="238086B9" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="2380873F" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809566" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380959E" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="23809572" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="238095AA" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Hz" LogReference="MAFHz" RequestID="2380882F" Eval="6.25*x" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1650" ChartMin="0" ChartMax="1650" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_adc_processed" LogReference="knock_adc_processed" RequestID="23808AA5" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_base" LogReference="knock_base" RequestID="2380AB77" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_var" LogReference="knock_var" RequestID="2380AB73" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_change" LogReference="knock_change" RequestID="2380AB79" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_dynamics" LogReference="knock_dynamics" RequestID="23808AB3" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_flag" LogReference="knock_flag" RequestID="2380813B" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Cruise Light" LogReference="CruiseLight" RequestID="238045C5" Eval="x" Unit="" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
      </Mode2>
    </ecu>
Old Oct 9, 2015 | 10:37 AM
  #1125
Boxador's Avatar
Hey Guys,
I have enabled Mode23 but I cant log 2byte load or psig or rpm.....
I found the right address in the MUT table for ie. 2byte Load and set it to evoscan(Request ID 238087B3) My RomID is 56910009.
I am logging Load ie 2734,19
the Eval is x*10/32
Responsebytes 2
scalingfactor .1
Speed, timing, tps is ok
I think its a problem with 2byte... what do I have to do to log 2byte?
