Evo X Logging
Old Nov 4, 2015 | 10:31 AM
  #1141
Sawdust's Avatar
I have the logcfg.txt mostly setup and tested for standalone logging, however I can't find any examples with the ZT-2 parameters (via serial to 2.5mm jack).
UPDATE: I found the type=zt-2 parameters section in one of the files in the ECUFlash samples folder. However the logged values make no sense. Maybe Zeitronix changed something in the current version of the ZT-2...
Old Dec 1, 2015 | 09:31 PM
  #1142
kaganader2's Avatar
Registered User
Originally Posted by razorlab
Evoscan v2.9.0099
Using the standard default evoscan ZTX request as it basically just gets it raw from the zeitronix unit:
Request: ZTX
Function: X
Units: Units
You have version v2.9.0099? I have 2.9.0092 and when I click check for updates nothing happens at all :'(
Old Jun 22, 2016 | 12:55 PM
  #1143
blackmambe_evo7's Avatar
59590004/5 help
I just recently upgraded from my 03 Evo 8 to a 2014 Evo X MR with SST.
Im still having some trouble and confused about a few exactly to do in order to get my car to log all the paramaters and how to correctly enable mode 23.
My ROM ID is 59590005 but inherits 59590004 so do i need to edit both of these xml files as stated in the "How to Mode 23..." thread over at evo ten forum, or just edit the 5959004 file thats being inherited.
Also I believe this is the right info posted by razorlab below that i need to enter into my .xml file correct?
Do i actually need to download and use the V1.1 application with the config.txt document, and if so what is the correct config.txt document for my rom id 59590005/4?
Ive already done several hours of reading and troubleshooting but theres very little info out there dealing with the 2013-2014 evo roms, and i cant get anything to work quite right. Any help is appreciated thanks!
2013-2014 is the same for USDM. Use the 59590004 address and XML
Code:
<ecu name="Golden 2013 USDM v1 EVOX">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="23808798" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor=".01" Notes="High Resolution RPM" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AB45" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="2380876A" Eval="(x*0.0482435)-[Baro]" Unit="PSIG" MetricEval="x*0.3326271-[Baro]" MetricUnit="kPa" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="AFR" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="10" GaugeMax="16" ChartMin="10" ChartMax="16" ScalingFactor="1" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="238087C0" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A5B" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A9F" Eval="x*1.000001" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="23808749" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808BB7" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AB80" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAFCalcs" LogReference="MAFCalcs" RequestID="23808FDC" Eval="x*100/16384" Unit="Load" MetricEval="" MetricUnit="" ResponseBytes="4" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAPCalcs" LogReference="MAPCalcs" RequestID="2380880A" Eval="x*100/16384" Unit="Load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Load (MIVEC) and (Timing if IAT GT 75F)" LogReference="LoadMIVEC" RequestID="238087C6" Eval="x*10/32" Unit="Load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="340" ChartMin="0" ChartMax="340" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="WGDC Correction" LogReference="WGDCCorr" RequestID="23808BB5" Eval="0.5*x-64" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="23809645" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="238086A9" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808687" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="238086A3" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="2380883B" Eval="x*1.243" Unit="mph" MetricEval="x*2" MetricUnit="kph" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808FCC" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088EC" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088FD" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Air/Fuel Ratio (Map)" LogReference="AFRMAP" RequestID="23808949" Eval="(14.7*128)/x" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front O2" LogReference="FrontO2" RequestID="238086B5" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="238086B9" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="2380873F" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809566" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380959E" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="23809572" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="238095AA" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Hz" LogReference="MAFHz" RequestID="2380882F" Eval="6.25*x" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1650" ChartMin="0" ChartMax="1650" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_adc_processed" LogReference="knock_adc_processed" RequestID="23808AA5" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_base" LogReference="knock_base" RequestID="2380AB77" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_var" LogReference="knock_var" RequestID="2380AB73" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_change" LogReference="knock_change" RequestID="2380AB79" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_dynamics" LogReference="knock_dynamics" RequestID="23808AB3" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="knock_flag" LogReference="knock_flag" RequestID="2380813B" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Cruise Light" LogReference="CruiseLight" RequestID="238045C5" Eval="x" Unit="" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
      </Mode2>
    </ecu>
Old Jun 22, 2016 | 01:02 PM
  #1144
RazorLab's Avatar
You need to enable Mode23 in your ROM by opening up that ROM and editing the Mode23 tables then flashing it back to the car.
*make sure the numbers in the table match the description before modifying them, if not, you could brick your ECU*
The bits you quoted are for Evoscan, not Ecuflash.
Old Jun 22, 2016 | 01:41 PM
  #1145
edit
Old Jun 22, 2016 | 01:44 PM
  #1146
Ok well what do i need to edit to enable mode 23 then? im confused on that part still i guess. heres a picture of my stock rom when i got the car, does this mean it already had mode 23?
Old Jun 22, 2016 | 01:56 PM
  #1147
RazorLab's Avatar
Flip those values to enabled and flash back to the car and you will be able to log Mode23 items via evoscan.
Old Jun 22, 2016 | 02:09 PM
  #1148
thanks
Ok so i just used increment on each of the values and it changed to enable, was it really that easy and its done correctly now?
I just want to be absolutely sure before i do flash it back to my ecu and "brick it" on accident.
Old Jun 22, 2016 | 02:10 PM
  #1149
RazorLab's Avatar
Yup that's it. It was not always that easy. Now it is!
Old Jun 22, 2016 | 02:14 PM
  #1150
Thanks so much!!! I think thats why i was so confused, everything now is made so easy for me since all you pros have spent so much time programming and writing code since the cars have been out for a while. Hence why i found so much detailed info on earlier methods that didnt apply to me, yet not on my current rom id, its been made easier over the years! thanks
Old Jun 28, 2016 | 07:10 AM
  #1151
tephra's Avatar
Yeh my fault I guess
Old Aug 6, 2016 | 11:14 AM
  #1152
EvoXEmma's Avatar
Originally Posted by Rico8638
Hello Sir
Do you have the .xml file for 52510010?
Any love for 52510010?
It's an EDM RA 1.8 A/T CVT with the 4B10 engine.
Willing to pay $$$ for the definitions.
File Type: zip
Old Sep 10, 2016 | 08:09 PM
  #1153
ozkarez's Avatar
im going to add to this giant thread, after the past week of trying to decipher whats going and getting a better understanding of ecuflash. i've got the handle of the basics of what to do.
my problem is with 58010005 (i actually have 58010006 but it wasnt listed so i inherited 58010005) and i am not getting access to everything. there are lots of options that are missing addresses and i have absolutely no idea on how to find them or fix the problem.
i've downloaded goldens xml's they change nothing. its the exact samething i got when i downloaded ecuflash which is the current version on the tactrix and evoscans website. im absolutely not flashing my car until i know this is straightened out.
like i said im at a loss here. i attached what i got from the car. thanks in advance to anyone who is willing to help.
File Type: bin
Old Sep 10, 2016 | 08:23 PM
  #1154
tephra's Avatar
i would recommend flashing 58010005 onto it.
if you persist with 06, you are going to have more problems down the line because its not defined correctly.
Old Sep 10, 2016 | 08:37 PM
  #1155
ozkarez's Avatar
Your eyes are about to roll so hard you gonna see the future. How do I flash 0006 in?
My guess would be change the identifier from 0005 to 0006 and flash it. Then when I pull it back from the ecu it'll be defined properly?
Also thanks for,that super fast response. I've been dreading asking about this stuff, but I've searched to no end,and haven't found anything like my scrap lol
