valet patch
Old Jun 3, 2009 | 11:58 AM
Drill_Sergeant's Avatar
Veteran: Army
valet patch
im just looking for strictly the valet patch from tephra.
i know he provided a combo of patches but im looking for ONLY the valet patch.
so if someone cost post this, it would be greatly appreciated.
for 2005 ROM ID 96940011
Old Jun 3, 2009 | 12:10 PM
rish197's Avatar
Doesn't exist. The code is written into the new rom. Why not just go an older version of the rom, and not use any other features?
Old Jun 3, 2009 | 01:16 PM
Fast_Freddie's Avatar
Veteran: Navy
Here is the original link but for the lazy people or the computer inept I have also extracted the info specifically for the 96940011 rom
https://www.evolutionm.net/forums/ec...-knockcel.html
Here are the two direct patches for the 96940011 rom to add to ECUflash depending on which version you have... It will add a new Tephra mods table to ECUflash just check which mods you wanna use. The following link will explain how to install the patch to your ecuflash rom.
https://www.evolutionm.net/forums/4830835-post.html
**For ECUflash versions 1.30 and below**
<scaling name="ECUTime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="1" storagetype="uint16" endian="little"/>
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16"/>
<table name="Tephra Mod Options" category="Mods" address="3FC0C" type="3D" scaling="uint16">
<table name="X" type="Static X Axis" elements="1">
<data>Value</data>
</table>
<table name="Y" type="Static Y Axis" elements="3">
<data>Enable Rev Limit Switching?</data>
<data>Flash CEL on Knock?</data>
<data>Enable NLTS?</data>
</table>
</table>
<table name="KnockSum Required for CEL" category="Mods" address="3FC12" type="1D" scaling="uint16"/>
<table name="Load Required for CEL on Knock" category="Mods" address="3FC14" type="1D" scaling="Load"/>
<table name="CEL on Knock flash time" category="Mods" address="3FC16" type="1D" scaling="ECUTime"/>
<table name="Valet Rev Limit" category="Mods" address="3FC18" type="1D" scaling="RPMLimit"/>
<table name="Valet Rev Limit Time to Activate" category="Mods" address="3FC1A" type="1D" scaling="ECUTime"/>
<table name="NLTS RPM Drop" category="Mods" address="3FC1C" type="1D" scaling="uint16"/>
<table name="NLTS TPS Threshold" category="Mods" address="3FC1E" type="1D" scaling="ThrottlePercentage"/>
<table name="NLTS Speed Threshold" category="Mods" address="3FC20" type="1D" scaling="VehicleSpeed"/>
**For ECUflash versions 1.31 and above**
<scaling name="ECUTime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="1" storagetype="uint16" endian="big"/>
<data>Value</data>
</table>
</table>
</table>
Old Jun 3, 2009 | 01:49 PM
Veteran: Army
thanks fast_freddie.
Old Jun 3, 2009 | 01:54 PM
Veteran: Navy
No problem... I know you only wanted the valet, but it is included with the others, if you don't want them then just check the valet mod only...
Old Jun 3, 2009 | 07:05 PM
pupo's Avatar
Let me know if this works because I wanted to do the same thing but I have a lot of paths set up for this rom (96940011) and I don't know if it is going to interferes with the other paths. I have rear O2 sim patch, ecu direct boots paths, 2 byte load rpm airflow, MUT Baud rate Patch, lean spool and a few others I can't remember.
Old Jun 3, 2009 | 10:03 PM
Veteran: Navy
It works cause I have everything that you listed except for ecu direct boost...
Old Jun 5, 2009 | 01:46 PM
pupo's Avatar
I will give it a try, thanks!
DormantBeast
13
Jul 9, 2017 07:38 AM
warp9
Nov 29, 2009 03:07 PM
evo8426
Mar 19, 2008 11:26 AM
SoCalRedLine
Feb 8, 2008 03:22 PM
jjm4life
Jan 13, 2007 08:57 AM
