Knocking Issues at Low Rpm/Low Load
Old Jun 8, 2009 | 04:11 PM
eag36's Avatar
Read through this. I had the same thing, now it's completely gone.
https://www.evolutionm.net/forums/ec...00-3000-a.html
Old Jun 8, 2009 | 05:40 PM
ace33joe's Avatar
Update: To reduce the rich knock (I assumed), I leaned out 140 load cells @ 2500 & 3000 rpm, then it seemed to be better for the first two pulls, but at the third pull, I got huge knocks! (Log attached) upto 24.
What would be the proper AFR target during the spool up? Because rich condition gave me mild knock trails, and lean condition also gave me knocks. TME RS does spool hundreds of rpm faster than the stock inconel turbo, so is it trickier to set it right?
Or can this be clutch related? I haven't seen any rpm shooting, but the clutch might make some noise during the spool-up since the stock clutch plate is spring loaded?
One more thing is that I definitely lost torque during spool up after leaning out.
I was also thinking about raising the knock load and reduce the knock sensor sensitivity, but I do not think mine is a phantom knock which many built or cammed engines might have, because it definitely changes with AFR.
Attached Thumbnails Knocking Issues at Low Rpm/Low Load-log.gif
Old Jun 8, 2009 | 07:03 PM
mindoftw's Avatar
Well the weird thing is the car was not knocking today. Im not sure if it was the race gas or not but i filled it up again today so i will see for the next couple of days what happens.
Eag36 i might have to do something like what is in your post, but im going to wait and see if this mystery knock comes back or not.
Edit: I would also like to note that my log looks something just like ace33joe's log looks. It is knock in the same exact spots.
Old Jun 8, 2009 | 07:08 PM
MR Turco's Avatar
let me know if you want to get together to take some more logs.
Old Jun 8, 2009 | 07:25 PM
ace33joe's Avatar
If you had high knock counts, I suggest you to make those specific rpm and load cells rich. At least I have never had those high knock counts until I made them leaner, although I had constant small number of knock counts over hundreds of rpms when AFR was rich.
Old Jun 10, 2009 | 09:46 AM
mindoftw's Avatar
Just an update, but it seems my knock has mysteriously gone away on its own. I havent seen any knock in the past couple of days even when i try to replicate the problem i was having before.
Strange? Could it have been the race fuel?
Old Jun 10, 2009 | 10:37 AM
MR Turco's Avatar
Well that is weird. Have you changed anything to the car? other than the gas? I still think it might be something loose under the hood.
Old Jun 10, 2009 | 04:36 PM
ace33joe's Avatar
Edited: I thought race gas prevented the knock, but you said race gas didn't solve the knock problem, and 93 pump gas did. Hm...strange.
Old Jun 10, 2009 | 06:17 PM
mindoftw's Avatar
Nope i didnt change anything, i checked to see if their was anything loose that could be causing the problem but didnt find anything. Its weird i have been using sunoco 93 for past few days and so far no knocking has occured since.
03GS-T
Oct 23, 2016 09:55 PM
tephra
Jan 31, 2009 08:17 AM
acamus
Oct 24, 2008 06:22 AM
erggy
Apr 23, 2007 08:48 AM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
