Knocking Issues at Low Rpm/Low Load
Old Jun 6, 2009 | 11:29 PM
mindoftw's Avatar
Hey i need help because i really do not know where to trouble shoot this. My car knocks randomly between 2700-3100 RPM like right when the turbo is about to spool.
Ive been trying to figure out what is causing this and decided that i would throw in some race gas and see if it still occured. I put in some 110 octane today and it is still knocking at the same exact spot.
Is this false knock? Someone also told me it could be caused by a bad coil pack?
Any help you guys can give me would be much appreciated.
Old Jun 7, 2009 | 12:08 AM
nonschlont's Avatar
we need more info on the car. built motor? Mods? post up a log, and we can take a look...
Old Jun 7, 2009 | 12:11 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
... ROM ID would help also...
Old Jun 7, 2009 | 12:38 AM
ace33joe's Avatar
I have the exact same problem. 94170008, 03 EVO stock except Apex-i cat back with 200cpsi metal cat + TME RS turbo. It almost always knocks just above 120 load from 2500~3000rpm. I suspect this is caused by Lean spool, because it is enabled from 2500rpm, and from 120 load value.
I am thinking about checking the coil packs myself also, but my car has only about 30k miles (although several track events so far), and I do not see knocks at higher loads/rpm with proper timing.
I guess I may have to further richen up AFR of 140 load cells at 2500 & 3000 rpm? It is set to 12.06 & 11.07 now, while stock ones are 12.80 & 11.07.
Old Jun 7, 2009 | 08:42 AM
mindoftw's Avatar
The car has for mods: BC272 Cams, AMS LICP, Walboro 255, 3" Megan DP, 3" Exhaust, HFC, Forge MBC, Forge DV, Open Filter intake setup.
The ROM im using right now is 94170015
Old Jun 7, 2009 | 08:46 AM
Evo8Emperor's Avatar
have you guys added in the new knock tables ? They helped me out a lot. My car is just plain loud at idle and driving. Between the flywheel and solid mount it makes for some noise.
Im not sure if you guys are having the same issue as me but it cant hurt to try.
Old Jun 7, 2009 | 09:49 AM
gear head's Avatar
You should probably verify the Knock with Det. cans before assuming It's phantom.
Old Jun 7, 2009 | 09:53 AM
mindoftw's Avatar
Det. Cans? how is this done?
Old Jun 7, 2009 | 10:03 AM
gear head's Avatar
Basically It's a set of head phones attached to the engine block.
This is what one of our fellow members did...
https://www.evolutionm.net/forums/ec...ing-knock.html
Old Jun 7, 2009 | 05:18 PM
ace33joe's Avatar
Update: I tried logging after richen up those two cells further, and I got more knocks. I found the mrfred's post about my knock problem.
https://www.evolutionm.net/forums/7060895-post12.html
It seems I am getting rich knock during spool up, and as mrfred described, I get small # of knocks over several hundreds of rpm.
I am not sure whether this is the case for you mindoftw, but I guess it is worth checking.
Old Jun 7, 2009 | 07:33 PM
one1fastevo8's Avatar
Mine is at 14.1 afr in the 2500-3000 at 120 load cell. You may want to lean it out a bit more not rich. The stock map is to rich and to aggressive on timing. And maybe lower the timing a degree or two.
Old Jun 7, 2009 | 09:02 PM
mindoftw's Avatar
No my knock is a lot worse then just 5 counts, it actually scares me because i have seen it go up to 18-20 counts. All the tips are good so far anymore would be good though so please keep em coming.
Old Jun 7, 2009 | 09:35 PM
bxracer1's Avatar
decrease the timing? a log would definitely help
Old Jun 7, 2009 | 10:07 PM
mindoftw's Avatar
Yah ill get another log tomorrow and post them up here.
Old Jun 7, 2009 | 10:55 PM
Evostacio's Avatar
hope you get it fixed man
