Evo Scan issue
Old Jun 9, 2009 | 10:18 AM
Motoxrider7's Avatar
Evo Scan issue
I have had this problem for a while now with my Evoscan 2.6v beta7.
When i go to log data i select LC-1 and everything seems to work fine. But when im done logging i check in Excel and there is all 0's in the WB collum along with knock collum. is someone could help me out. Maybe there is a new version that is fixed and i havent downloaded it yet or something.
Thanks
Rob
Old Jun 9, 2009 | 10:55 AM
evo8426's Avatar
for some unknown reason my lc-1 was only logged 0's this morning when i did some logs on the way to get breakfast and back home. the led light was flashing several times then pausing..when i got home i let the car sit for a little over an hour and recalibrated the sensor and the led light stayed solid this time so i think that may have been the reason for mine logging 0's. have you tried recalibrating? im using evoscan 2.6 beta 8
Old Jun 9, 2009 | 11:10 AM
Well I did a calibration several times and still 0's
i had to of done something wrong in loading 2.6v beta7
Im going to load beta8 after work and try it out. Thanks
Old Jun 9, 2009 | 11:58 AM
evo8426's Avatar
i got mine to work just about 45 seconds ago..i started the datalogging, went up to the wideband tab, selected all the different com ports one at a time (com5, then 4, then 3, and then back to 5) and then selected the one that i knew worked previously (com5) and voila it worked haha. to make sure its logging while you sit still in the car i would recommend you rev it just a little bit to get the numbers showing up. hope this helps
Old Jun 9, 2009 | 02:34 PM
Well mine still dont work. so i totaly wiped out my laptop and im going to get rid of Vista and get XP Pro. Cuz i think some of my Drivers were deleted when doing something thanks for the help and once i do this ill get back to ya.
Old Jun 20, 2009 | 12:12 PM
evo8426's Avatar
im not sure if you sorted this issue out but i ran across the same problem the other day. make sure you have your lc-1 plugged into the computer before you open up evoscan, otherwise if you open evoscan and then plug in the lc-1 to the laptop you will get 0's in the logs
rstchris
May 22, 2011 02:30 AM
Live4Redline
May 13, 2009 07:57 AM
sleeperevo8
20
Jul 8, 2007 01:09 AM
Robert_K
Nov 16, 2005 06:12 AM
mrbkkt1
Dec 12, 2004 07:26 PM
