how to avoid frustration installing Blitz DTT
Old Dec 8, 2004 | 10:51 PM
mrbkkt1's Avatar
first off, the photos:
okay the first image is my brand spanking new BLITZ DTT DCII. I installed it myself. New? what happened to the button you say? Well, I'll explain.
First off installing this is actually pretty easy. First get the TT and a matching harness. i couldn't find one locally from blitz so i got the HKS one instead for evo's 93-2000. i figured the wiring would be the same. WRONG. the plugs match but the wiring is backwards or so i thought. the first thing that i did was to take out the little m/f- pins/sockets and reverse them so they would match the factory wiring. after i hooked everything up, the car started and wouldn't stop starting. thank you very much to member benji for his wiring codes.
after studying his codes and the blitz wiring diagrams i finally got everything to work right. I routed the vacuum tap(2nd pic) which i got from the last part of the manifold) through the firewall. I looked for about half an hour trying to find a place to put my tube. 3rd pic is where there is a grommet. it is located passenger side behind shock tower. just push it through. after you get grommet out, you can drill it (solid rubber) but i just wanted to finish.
Here is the part where i get to without frustration. when installing the DTT, i reccomend removing strut bar, lower dash panel, glove box, the little panel on side of glove box, the passenger front kick panel (left and right), the passenger side door sill plate ( need to take off for kick panel) AND OF COURSE, THE STEERING COLLUM. (3screws).
1 various notes. to remove the glove box, there is the left side tab. pull the glove box out halfway, then push on tab. after that, you can squeeze the right side tab out, and then open the box all the way down to remove.
2 I used velcro to mount "brain" of timer to metal plate. it's much easier to use than 2way tape.
3. just ground the damn purple wire. i don't know how many of us park w/o the parking brake anyways. all the usdm evo's are sticks.
4.when reassembling the steering collumn, watch out for both the wiring harness, and the rubber surround in the key area.
5. you have to line up the bottom part of the steering collumn w/ the screw holes. the 2 front screws go directly into the collumn, while the back screw goes into the top part of the collumn.Put the 2 front sscrews in first, make sure they go into the holes in the steering collum. then do the 3rd srew in the back.
6. on 05 evo's on the side near the glovebox is the brain for the acd. it makes it hard to get access to the gommet hole but it is manageable.
7. Don't drop the screen of the unit. mine fell apart and all the buttons went flying. i have the last stall in my structure so the last button is in the grass somewhere, that is why i have only 2 buttons on my brand new turbo timer.
8. the wiring diagram from benji( search for ignition wiring, i'm to lazy to put in another link) was extremely helpful in making my hks 93-00 evo harness, work w/ my 05 evo and blitz dtt. Once again, i don't know who you are benji but thank you very much.
9. any questions, p.m. me and i will be more than glad to help.
Good luck
Old Dec 8, 2004 | 11:00 PM
mrbkkt1's Avatar
i'll post some more pics and experiences later but i'm pooped out now,didn't even have time to play w/ new toy yet.
Old Dec 8, 2004 | 11:02 PM
mrbkkt1's Avatar
oh btw, if anyone has a dtt thats broken, i need a new power button.
Old Dec 9, 2004 | 04:38 PM
mrbkkt1's Avatar
made a makeshift button from an old remote control. but wish i could have a stock button.
Old Dec 12, 2004 | 07:26 PM
M3lachsilber's Avatar
choad
Discuss thread here!!
rayman0690
Jan 4, 2026 07:20 PM
xanderracing
24
Feb 14, 2024 12:14 PM
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
Blak94GSX
21
Feb 4, 2015 03:02 PM
Blacksheepdj
Lancer How Tos / Installations
Dec 3, 2007 03:48 PM
