How low for timing to be dangerous?
Old Jun 15, 2009 | 12:53 PM
  #91
house_of_senate's Avatar
Originally Posted by TTP Engineering
I would just reduce your boost level. You cannot force a car into accepting too much boost. I will either take it and like it or it won't. There are many factors contributing to what an engine will accept.
Your timing numbers are an indicator that you are trying to force the car. I would revamp the whole map based on lower boost.
7* at 7500 is ridiculous. There are pumpgas cars running 35psi boost at 7*.
I would reduce the boost until the car will accept a minimum of 11-13* at that rpm.
The problem is the car will not take more timing period, even at 20 psi. I raised boost up to 25 in hopes of bringing power back up and it didnt really change knock sums. The car just hates to make power.
Old Jun 15, 2009 | 12:55 PM
  #92
daymean's Avatar
Originally Posted by house_of_senate
With 4 degrees at peak tq climbing to 7 degrees at 7500, I will mostly see no more than 1 count through the pull, but when doing constant pulls or just 1 out of 4 pulls on average I will see anywhere from a 5 count up to 10....this usually isnt at the same rpm and it usually doesnt hold throughout the pull.
Do you have lean spool enabled?
Old Jun 15, 2009 | 12:58 PM
  #93
Ls is disabled, I have also changed the afr from 10.5 to 11.5 with no change in knock. You guys can read my first post in this thread for more background
  #94
JohnBradley's Avatar
There has to be a mechanical cause to the type of knock you are seeing. I have run 91 pumpgas cars far harder with far more timing. Are there any mechanical changes to the engine itself? How intermittent is the knock and can you lift and reply 100% throttle and either make it appear or disappear? What intercooler are you using (what are the underhood IAT), were the lifters properly bled, is there anything possibly touching the downpipe?
Old Jun 15, 2009 | 01:02 PM
  #95
TTP Engineering's Avatar
Did you change your timing belt recently? Do you have adjustible cam gears?
Old Jun 15, 2009 | 01:06 PM
  #96
Stock engine besides cams, stock motor mounts, ams intercooler. Just depends on lifting and going back into it, sometimes will and then sometimes wont cause knock sums. Base timing is spot on, lifters bled good and are quiet, downpipe is not touching anything.
Old Jun 15, 2009 | 01:09 PM
  #97
Nope, car has been doing this for a year, Im ready to sell it. You can search for my other thread where Mellon talks about it, he worked on it for awhile. Im on a iphone now otherwise I would post it.
Thanks
Old Jun 15, 2009 | 01:31 PM
  #98
RoadSpike's Avatar
Just a quick question are you running a cat? And if so was it checked to make sure it didn't melt on heat or a rich afr?
Old Jun 15, 2009 | 01:33 PM
  #99
rolly1818's Avatar
Registered User
what rom are u using? had a similar problem where the car would apply timing from a map(still did not figure out where lol) and i would get a lot of knock no matter what timing i put into the map.
Old Jun 15, 2009 | 01:41 PM
  #100
No cat, and 88590015
Old Jun 15, 2009 | 02:44 PM
  #101
headgasket could exhibit these symptoms
  #102
I have seen this with my car when the clutch is done and the springs in the hub rattle (like a broken cage for instance). How new is the clutch?
aaron
Old Jun 15, 2009 | 03:46 PM
  #103
MR Turco's Avatar
aaron
thanks i think i may have figured something out on my car.
Old Jun 15, 2009 | 04:11 PM
  #104
Compression test shows great actually, have not done a leak down. Clutch is a old exedy stage 1 that was in the car when I bought it, it hasnt slipped at all yet and my ears at least cannot hear any clutch noise.
Old Jun 15, 2009 | 04:13 PM
  #105
RoadSpike's Avatar
Have you tried making a set of det cans? Maybe you could hear mechanical noise that is unusual that way?
