How low for timing to be dangerous?
Old Jun 30, 2009 | 12:34 PM
  #121
house_of_senate's Avatar
Originally Posted by rolly1818
i have been able to see 12/11 on pump with 20psi.
Your making more power going that route? Compared to 22 psi and a few degrees less timing.
Old Jun 30, 2009 | 12:46 PM
  #122
spdracr's Avatar
[QUOTE=03whitegsr;7157398]Aren't you guys a little too focused on trying to run XX boost instead of trying to figure out where the car is actually the fastest? Tune the car well at say 20 psi, 22 psi, 24 psi, etc then go to the track and do several runs at each boost pressure. You may just find that on a smaller turbo, the lower boost actually makes the car just as fast, but greatly reduces the stress on everything.
finally an intelligent answer
big boost on little turbo means ur blowing hot air run less boost and more timing u get more torque and useable power
Old Jun 30, 2009 | 03:27 PM
  #123
JohnBradley's Avatar
To a point, yes. Running over 26psi is probably a point of diminishing returns but I really dont think you make enough up under that to say that running 22psi and more timing is better than 26 and less timing.
Old Jul 2, 2009 | 04:06 AM
  #124
rolly1818's Avatar
Registered User
22psi is too much for me on the stock turbo (no porting or water/meth)
^^ what i think
Old Jul 2, 2009 | 10:49 AM
  #125
03whitegsr's Avatar
My point is that blindly setting a boost level and thinking it's the best is stupid.
Testing will revile what is actually the best for your particular setup.
Old Jul 2, 2009 | 10:55 AM
  #126
Appauldd's Avatar
Testing will reviele what is actually the best for your particular setup.
I completly agree. Every car is different. some will like more boost and less timing, while others will like less boost and more timing.
Only through tuning will you find that balance.
In my case I raised the boost because of my mods and then tuned, which requred reducing the timing, to where I am content. Sure there may be some power left on the table, but I am not one to push to the limits. Safe and relaible is where it is at.
Old Jul 9, 2012 | 09:12 AM
  #127
RJSP's Avatar
Had to revive this too see what are the views now on 0 - 1 degree timing at peak torque and melting components at the track (prolonged wot). Did the OP solve his problems?
Old Jul 9, 2012 | 12:22 PM
  #128
NOMIEZVR4's Avatar
question for you guys, when its mentioned that you guys have 3-4 degrees of timing at peak tq and 14 up top for example, does that mean 3-4 degrees/14 degress of timing advance on the timing map? So +14 over what it is stock?
Old Jul 9, 2012 | 01:07 PM
  #129
dolphin888's Avatar
In the map, not plus...
Old Feb 13, 2013 | 09:11 PM
  #130
kevin8086's Avatar
Did this ever get solved? I'm on 93 oct. cossie m2 cams and fp red. I am at 24-25 psi and can only run 1-2* peak tq and 7* at 7500 rpm. Anything more and I pick up 4+ counts of knock. Making 375whp and 345wtq. Raising the boost doesn't do much and lower boost with more timing doesn't make more then 345whp 310ishwtq
Old Feb 13, 2013 | 10:00 PM
  #131
evo8426's Avatar
Can you post a log and a screen shot of your timing map?
Old Feb 13, 2013 | 10:43 PM
  #132
kevin8086's Avatar
I only have my phone right now but I can tomorrow
Live4Redline
Jul 17, 2024 07:09 AM
Ray521
Sep 10, 2015 11:10 AM
ChipperEvo
Cobb AccessPORT
Dec 2, 2012 07:33 PM
mrfred
39
May 18, 2011 05:05 PM
GTR2009
12
Jul 22, 2009 12:46 PM
