Help Please with Boost Control 30R and Tial
Hi there guys.
Im wanting to control my boost using the stock ecu on my 30R with 44mm Tial external to @35psi.
I have wired in a Mac valve N/Closed to the top of the wastegate, the same as when using my ProfecB. Everything is working okish as long as I dont want to boost too high.
I basically just want to run on duty cycle only and not worry about error correction etc at the moment. I thought that increasing the Load Offset to allow for running up to 400load would let me just set the duty cycles as i want.
I set the Load Offset to 200 and increased all the Boost Desired Engine load tables to 159.4, BUT the ecu keeps reducing WGDC as soon as the load goes over 220-240 ish. When I first hit into boost the load gets to 300 then gets massively corrected down to 220 then the WGDC goes higher again and allows the load to pick up again then gets dropped again.
Also at idle the WDC is like 78% is that normal????
stockduty_200loadoffset_159%load.zip
My vehicle is a Mitsi Airtrek Turbo 83540008 rom
http://www.mediafire.com/?sharekey=a...4e75f6e8ebb871
Could someone check thru the def below and make sure the address for load offset is correct.
<table name="WGDC correction delay" category="Turbo" address="1af0" type="1D" level="1" scaling="uint16"/>
<table name="WGDC Correction update delay #2" category="Turbo" address="1af3" type="1D" level="1" scaling="uint16"/>
<table name="Boost Control Load Offset" address="1b0a"/>
<table name="Turbo Boost Error Correction" address="474c">
<table name="Boost Error" address="61ea"/>
</table>
<table name="Boost Desired Engine Load # 1" address="47a6" level="4">
<table name="RPM" address="614e" elements="16">
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<table name="Boost Desired Engine Load # 2" address="47bc" level="4">
<table name="RPM" address="614e" elements="16" scaling="RPM">
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<table name="Boost Desired Engine Load # 3" address="47d2" level="4">
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<table name="Max Wastegate Duty # 1" address="4764">
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<table name="Max Wastegate Duty # 2" address="477a">
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<table name="Max Wastegate Duty # 3" address="4790" level="4">
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<table name="Wastegate Solenoid Activation RPM-Active" address="16cc" level="4"/>
<table name="Wastegate Solenoid Activation RPM-De-activate" address="16ce"/>
<table name="Wastegate Solenoid De-activation RPM-De-activate" address="16d0"/>
<table name="Wastegate Solenoid De-activation RPM-Re-activate" address="16d2"/>
Thanks in advance!!
Aaron
</table>
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
<data>500</data>
<data>1000</data>
<data>1500</data>
<data>2000</data>
<data>2250</data>
<data>2500</data>
<data>2750</data>
<data>3000</data>
<data>3500</data>
<data>4000</data>
<data>4500</data>
<data>5000</data>
<data>5500</data>
<data>6000</data>
<data>6500</data>
<data>7000</data>
</table>
</table>
Thanks in advance!!
Aaron
Wastegate spring is 18psi and is running fine on that as Im doing that while I get the control sorted.
I know that it should work fine hence the reason that I think my definition is wrong somewhere and not allowing me the control that I should have.
