Opinions on tune...
Old Jun 20, 2009 | 04:41 PM
  #31
rolly1818's Avatar
Registered User
350 for 23 psi is good what are ur mods?
what octane?
Old Jun 20, 2009 | 04:53 PM
  #32
bsmart82's Avatar
The comparison pull flared a bit up top so it's about 344-5 dynojet-sim estimated. Mods are BR 3" turbo back exhaust, BR air filter, Forge MBC@24 psi peak, tapering to 17-18, 93 octane, and Zeitronix WB.
Old Jun 20, 2009 | 05:40 PM
  #33
rolly1818's Avatar
Registered User
damn i made 315 whp and 317 wTQ on an SAE corrected dynojet.
3" TBE with 24 psi to 18psi @ redline.
whats settings did u use in the virtual dyno?
Old Jun 20, 2009 | 05:54 PM
  #34
bsmart82's Avatar
I used Jack of Trades sim, set for Evo 9 MR, 3rd gear pull, 3350 weight, 195 driver, dyno jet dyno, smoothing factor 3. I think the numbers are a little high, but hopefully I will be on a real dyno soon. I emailed you the excel file and screen shot. If you have a recent log, you should put the data in the comparison cells and post a ss.
Old Jun 22, 2009 | 02:31 PM
  #35
R/TErnie's Avatar
lean it out from 4300-5700 you're still too rich. 11.4-11.5:1
Give it more timing. Add 1 degree from 220-300 across the WHOLE rpm range. log another 3rd gear pull.
