Virtual Dyno Room-Dyno Simulator
Old Jun 9, 2010 | 07:27 AM
  #946
bbarnhill's Avatar
by the way ... does anyone have any decent suggestions on names for the program Im writing? Virtual Dyno Room has already been taken and I dont know how I feel about HPCalc.
Old Jun 9, 2010 | 10:38 AM
  #947
Jack_of_Trades's Avatar
The reason for the trimming is still relevent even with a tps lookup. When people copy/paste into vdr, they generally only paste the adjacent cells to the wot tps data. Sometimes the last line of data seems to create artifacts and skews the end of the graph. I will send you a log with such an anomaly for you to try in your version.
I would love to use every line of data rather than the 50rpm lookup but the issue is with the smoothing. The more lines, the more columns of smoothing (I.e; averaging) I need. To reference those columns, I would need an immense amount of smoothing points for large datalogs. Maybe u can share how you guys are averaging? I average the adjacent cell, plus the one above and below it.
Old Jun 9, 2010 | 03:26 PM
  #948
bbarnhill's Avatar
I am doing it all in my code but basically the same way you are doing it.
Old Jun 9, 2010 | 03:43 PM
  #949
donour's Avatar
https://www.evolutionm.net/forums/ge...-inclined.html
  #950
Does anyone have an insanely large datalog pull with tons of data per second for me to test with?? If so, please email it to me at punkdivo78 at hot mail dot c.om (I did that for you Tephra,lol).
Old Jun 9, 2010 | 04:04 PM
  #951
Ok, now I kNOW I am out of my realm......knee deep. Unfortunately none of the images show up for me and the PDF link didnt work either
With VDR, the only way I could get any repeatable data was by first LOCKING the range of data used by finding the closest RPM point that matched my 50 RPM increment. So basically from 2450rpm and up, it searches in 50rpm increments. This allowed me to have control over the amount of data I would be smoothing. The problems occur at the ends of the curves though, especially the highest rpm range. This is due to a lack of 'even' averaging since the data just ENDS. Donour, if you know a way I can try to incorporate this into an excel spreadsheet, I'd love to try it if I can even understand it,lol. Other than basic algebra, I have limited experience which advanced mathematics.
As you stated in your other thread, VDR somehow did a fair job of mimicking dyno plots I used to build it. *shrug* Dont ask me how,lol. Anyone who has tried deciphering my formulas can attest to the cluster f&ck it became up til this point. I should have stripped it down and rebuilt it long ago.
Old Jun 9, 2010 | 04:20 PM
  #952
ziad's Avatar
jack... thanks to livemap... i get a lot of data points..... but most are 3rd gear pulls... let me see if i can find a 4th gear and i will email.
EDIT: shouldnt that be diva instead of divo
Old Jun 9, 2010 | 04:35 PM
  #953
ziad's Avatar
ok email sent.. about 240-250lines for the 4th gear pull... i am sure u will get more ppl helping.
anyway a suggestion... instead of re-inventing the wheel... just use someone eleses smoothing functions... the ones before might be good.
Old Jun 9, 2010 | 04:38 PM
  #954
Heck no, I am am manly Diva, hence the 'o' lol.
Old Jun 9, 2010 | 04:55 PM
  #955
ziad's Avatar
ahh btw the vdrs are showing the anomality... where it just jumps up too much unbelieveably.
Old Jun 9, 2010 | 04:57 PM
  #956
Been working on that all day. I'll get it....eventually.
Old Jun 9, 2010 | 05:37 PM
  #957
What are the largest file sizes people have seen? I thought i was able to log over 1000 lines before. Just RPM logging with nothing logging to the screen, I think.
Old Jun 9, 2010 | 06:44 PM
  #958
tephra's Avatar
as in logs?
i regularly have 20k lines/rows of logs
Old Jun 9, 2010 | 07:19 PM
  #959
Originally Posted by tephra
as in logs?
would you mind sending me a 3rd or 4th gear pull datalog then??
  #960
tephra's Avatar
oh do you mean longest log for 3rd/4th?
thats only about 120 rows
but the whole log from start to finish is 20k
