sudden enrichment and stalling
Old Jul 1, 2009 | 08:24 PM
  #31
laakness's Avatar
Try twisting the throttle by hand. Does it stick/give resistance or catch at all in the throttle body?
Old Jul 2, 2009 | 07:31 PM
  #32
nitz's Avatar
there is slight feeling of the throttle plate just touching at one point, but it definitely does not get hung up and stay open as far as i can tell. i even put an extra wind in the spring so it snap backs with a bit more force.
Old Jul 3, 2009 | 01:01 PM
  #33
nitz's Avatar
quick update.. adjusting the maf screw made no difference in lowering airflow at idle. i still see the following.
43Hz AC off
56Hz AC on
Old Jul 3, 2009 | 05:24 PM
  #34
Appauldd's Avatar
Is your MAF still upside down???
Old Jul 3, 2009 | 10:11 PM
  #35
wreckleford's Avatar
Have you adjusted MAF size in ECU Flash? I have found I need to lower this with strokers as the load hits higher values than the 2.0. This is why your load goes up to 80-90 just off idle.
Old Jul 3, 2009 | 10:14 PM
  #36
Appauldd's Avatar
So you are saying change the value for MAF size from stock of 357.5 g/s to ? ? ?
Old Jul 4, 2009 | 08:58 AM
  #37
nitz's Avatar
yes.. i don't have the option to turn it right side up due to how the intake box is designed and length of the wires of the maf plug. i don't think it's an issue though since it ran just fine with stock motor and bolt-ons.
Old Jul 4, 2009 | 09:14 AM
  #38
nitz's Avatar
i think there is some posts of buschur doing this on his project white 2.3 since he was hitting very high loads, but in the end he got his maf scaled and was able to go back to the stock size maf. didn't seem like anyone really recommended changing the maf size, but i'm going by memory since search is useless here. i'd imagine doing this at this point would affect load across the board and you may have to make adjustments to your tune depending how drastic the change.
89turbosupra
Feb 12, 2016 06:03 PM
MLucas13
Oct 23, 2015 06:31 PM
mc14
70
Sep 2, 2015 12:25 AM
evo854880
10
May 15, 2012 09:24 PM
Murf
Nov 14, 2008 03:15 PM
