EvoScan v2.6 B16 Logging Problems with Zeitronix ZT2
Old Jul 3, 2009 | 10:11 PM
rawkus's Avatar
Hello all,
I just installed my wideband today and when I try to log with EvoScan the readings are all over the place, jumping up and down all the time. If I disconnect and unplug the USB to Serial adapter for the Zeitronix unit everything reads fine within EvoScan. The Zeitronix software works fine and if I use Mitsulogger 2.0 beta I can log everything fine. Just appears to be a problem with EvoScan. Any ideas?
Dan
*Update*
It was my USB-Serial Hardware, went with Belkin from Staples and have had no issues.
Old Jul 3, 2009 | 11:01 PM
Appauldd's Avatar
Sounds like a driver issue with the serial adapter. Is the COM port set properly in EvoScan???
Old Jul 4, 2009 | 07:50 AM
rawkus's Avatar
Yes, I selected Com port 6, Zeitronix ZT2 and selected External Wideband A/F Ratio in the items to data log area.
Dan
Old Jul 4, 2009 | 02:48 PM
mitsuv's Avatar
I have the same problem with mine sometimes, i reboot my laptop and it works. To avoid this bug i plug the usb cable when the system is started, . I think i have a conflict between my touch pad driver and usb to serial adapter driver.
Old Aug 19, 2009 | 12:23 PM
rawkus's Avatar
*Update*
Dan
Old Aug 19, 2009 | 04:43 PM
tephra's Avatar
2.6 Final is out - you should update to that
even thou its already fixed
Old Oct 22, 2009 | 10:59 PM
XSivPSI's Avatar
The zeitronix software works fine for me and logs AFR but EvoScan 2.6 isn't logging AFR for me. I set it to com port 1 which is the same port the zeitronix software uses but its not logging. My laptop has a serial port so I'm using that. Do I have to get a serial to USB adapter for evoscan to log properly?
Old Oct 22, 2009 | 11:11 PM
SoCal Rally's Avatar
Did you check the necessary 'External Wideband A/F Ratio' field (from the 'Items to Data Log' pane on the left hand side) as well as all the desired/relevant 'ZTX xxx' fields (in addition to selecting 'Zeitronix ZT2' from the 'Wideband (WDB)' drop-down menu)?
Old Oct 23, 2009 | 12:17 AM
XSivPSI's Avatar
I had it checked in the 'Realtime logging data graph' window but not in the main window... So yay it works. Boo for being a retard.
Old May 19, 2011 | 11:36 AM
blacktab420's Avatar
Done everything mention ^^^^ and still not working. It's weird because it works in the zeitronix software.
Old Nov 3, 2011 | 10:49 AM
acidtonic's Avatar
Same issue here with my Zeitronix wideband.
Zeitronix software works, Evoscan shows 0 for the value. Evoscan worked the first time, but threw a fit ever since. Rebooted, removed driver, reinstalled driver, etc. Randomly it works but refuses to work after I stop logging during that session.
I'm going to try a different Serial->USB adapter. Currently using a TrendNet adapter found at microcenter for $15.
I'll try to follow the post by Rawkus and grab a Belkin from Staples after seeing that it fixed his issue. I'd prefer not to wire into the ECU but it if keeps refusing to log then I might have to.
Old Oct 4, 2013 | 05:47 PM
bigdnno98's Avatar
I'm bumping this 2 year old thread because I need the formula for the ZT2 in EVOscan. I found one on here and it doesn't work. AFR on EVOscan doesn't match my LCD display. Does anyone have the correct formula/scaling for the ZT2 in EVOscan?
stefenboy
May 20, 2016 07:51 PM
Dimmoun
Apr 19, 2016 12:20 AM
Danner
Aug 13, 2011 11:13 AM
hearnoevo
Sep 14, 2010 08:15 AM
krillin
Jan 25, 2007 11:53 AM
