Ecu flash works just fine Evoscan doesnt recognize obdII usb.
Old Jul 23, 2011 | 10:27 AM
Danner's Avatar
Anyone have this problem? It seems like evoscan doesnt recognize my 1.3 tactrix cable. Do I have to change a setting on evoscan to read this cable?
Old Jul 23, 2011 | 10:38 AM
evo8426's Avatar
make sure you have OpenPort 1.3x selected and Mitsubishi MUTIII checked in the upper left hand of evoscan
Old Jul 25, 2011 | 08:00 AM
Danner's Avatar
Yep I have both of those selected. Hmm anything else I need? Should both the 9 pin and the little white connector be plugged in? I seem to remember trying several different ways.
Old Jul 26, 2011 | 05:34 AM
Danner's Avatar
Nevermind I got it. Had the wrong damn box checked. Works like a gem
Old Aug 11, 2011 | 04:29 AM
17579EVO9MR's Avatar
I'm actually having problems too. It worked yesterday, and then it stopped. It won't even find my cable. Also was having problems with ecuflash 1.29. On windows 7 when you open a program it has a little icon show up on the task bar. That's all it would do for me. The actual program wouldn't open. So I deleted it and reinstalled it, and that's when I got all these problems. Where can I reload the drivers for my reflashing cable? Any other thoughts as to what might be going on?
Old Aug 13, 2011 | 11:13 AM
CDrinkH2O's Avatar
Is it a new cable? I just received a bad 1.3R from Evoscan and it wouldn't work with my laptop and Win 7.
I had a very similar problem to you after uninstalling and reinstalling the Evoscan software. First, like you, I though it was mising drivers. I had to eliminate each component, one at a time, before I got to the cable.
When you plug the cable in it should install the drivers it needs to work with Win 7 and the Evoscan software. You should not need to install drivers separately.
If possible, borrow someone elses cable, that you know works, to eliminate it as a source.
Good luck.
twisty
Jul 15, 2016 11:01 AM
johntrav
May 7, 2014 08:45 AM
wizzo 8
Nov 7, 2011 09:49 PM
jrsimon27
Jun 4, 2009 09:13 PM
bigric09
Dec 2, 2006 07:00 AM
