EGTs for Road Racing
Old Jul 10, 2009 | 10:30 AM
MR Turco's Avatar
Anyone have any input on safe to agressive EGT levels for road racing. My street, autox tune peaks shy of 1600*F in 3rd. I am sure 1/2nd gear are lower for autox. I am more worried about road racing. I figured i should turn the boost down but i wasn't sure.
In the past, i have peaked almost 1700* with no ill effects however that was only 1-2 pulls, where lapping a course might cause irreversible damage.
Any advice would be much appreciated.
Thanks
Mike
Old Jul 10, 2009 | 11:25 AM
GST Motorsports's Avatar
I'd try to keep it at or under 1600 in 4th
I've hit 1700 a couple times on track in my personal Evo with no issues but I wouldn't want to make it a habit.
Should always check EGT's in 4th if possible as that is the gear you will really have to worry about them.
Old Jul 10, 2009 | 11:48 AM
Kracka's Avatar
Yup, try to keep them at/below 1600F.
Old Jul 10, 2009 | 11:59 AM
detroit pistins's Avatar
can you explain why 4th gear temps are more important pls.
thanks
Old Jul 10, 2009 | 12:03 PM
MR Turco's Avatar
that's pretty much what i thought in terms of temps. I never test in 4th, mainly cause i don't like winding out 4th on the street but that is definitely a good point.
Thanks everyone.
Old Jul 10, 2009 | 12:05 PM
MR Turco's Avatar
thanks
4th gear is longer allowing for more time for everything to heat up as well as more load on the motor. If you are hitting close to 1600 by redline in 3rd you will probably be a bit higher in 4th and even more in 5th
Old Jul 10, 2009 | 12:10 PM
EVO8LTW's Avatar
What about 5th gear? Wouldn't those EGTs go even higher?
Does fuel affect EGTs or just make it safe to run higher ones?
Old Jul 10, 2009 | 12:33 PM
ah cool, it makes sense.
thanks
my guess is a 5th gear pull to redline would get u to 150mph+, i don;t think people are able to try it out for the obviouse reason.
Old Jul 10, 2009 | 12:35 PM
MR Turco's Avatar
5th gear would be higher.
Fuel, timing, boost all affect EGTs.
Old Jul 10, 2009 | 02:13 PM
black E's Avatar
were is your probe located?
Old Jul 10, 2009 | 02:15 PM
MR Turco's Avatar
Runner 2.
Old Jul 10, 2009 | 02:18 PM
I thought runner 1 is usualy the leanest and that's where the probe should be at, << is this right?
Old Jul 12, 2009 | 05:03 AM
EVO8LTW's Avatar
Well, we're talking about road racing tuning, which involves a race track. I'm pretty sure I'd hit 150 on the back straight at VIR with my current power level and I plan to log the next time I track the car.
BTW, my probe is in runner 1.
Old Jul 12, 2009 | 06:51 AM
honki24's Avatar
My probe is in the collection portion of the manifold as fluid dynamics tells me the temp will go up when the pulses all meet up and the pressure goes up. It's true. I regularly see 1700-1800 there. I can't speak for how much I trust my sensor, but that's what it says. I do have some heating issues. I just warped my SS 02 housing. Strange because I'm only running normal timing (3 degrees peak torque up to ~14 at redline) at 23psi on the stock turbo and 11.5:1 AFR with water injection.
Old Jul 12, 2009 | 07:11 AM
nothere's Avatar
honki
do you road race? have you logged a driving session?
