Logworks 3 - how to make it log 2 bite load
Old Jul 11, 2009 | 07:57 PM
YaroRS's Avatar
Does anyone know how to configure this program to log 2 bite load. As I understood in previous versions there were protocol file, but in 3rd there is no such thing !
Old Jun 15, 2010 | 06:04 AM
Danieln's Avatar
After one year.....bump from me also.
Maybe there is a solve....
Old Jun 15, 2010 | 06:40 AM
l2r99gst's Avatar
It's been years since I have used LogWorks to actually log, but IIRC LogWorks 3 will use the protocols.xml that is in your system from the LogWorks 2 install.
Just make a datachannel to log each byte of the 2 byte load, then in the LogWorks app, you make a math channel to combine the two datachannels into one. The instructions are in this forum somewhere.
Old Jun 15, 2010 | 07:33 AM
Danieln's Avatar
Cheers mate
I will do that...
Old Jun 15, 2010 | 07:35 AM
Danieln's Avatar
What I found was only this....
https://www.evolutionm.net/forums/ec...-logworks.html
Old Jun 15, 2010 | 07:57 AM
l2r99gst's Avatar
That seems to explain it well enough. There are a few other posts as well, but that should get you going.
Old Jun 15, 2010 | 07:59 AM
Danieln's Avatar
thanks mate.....
Old Jun 15, 2010 | 08:09 AM
Danieln's Avatar
Unhappy
My issue is related with LM-2 and Evoscan
Hamish said to me that he needs LM-2 logging specs to insert the logging protocols in Evoscan.
At this moment LM-2 ant Evoscan via USB serial is not working.....
Old Jun 15, 2010 | 09:18 AM
VGergo's Avatar
Hello
I dont have logworks 2 can not downloading it. I have only logworks 3 but nowhere find any protocol.xml files
Old Jun 15, 2010 | 01:36 PM
Danieln's Avatar
Try here...
http://www.hqtec.se/en-t-download.aspx
Old Jun 16, 2010 | 04:52 AM
VGergo's Avatar
Originally Posted by Danieln
nice thank you !
Old Jun 16, 2010 | 05:57 AM
Danieln's Avatar
Tell me if you will menage to connect with Evoscan via serial 2 USB cable......
Old Jun 16, 2010 | 09:24 AM
VGergo's Avatar
Added the following line to my Protocols xml file : IS that okay ? Why my Load error and wastegate duty cylce are red ?
I didnt find out what to add to able log target boost, boost error psi ?! Someone coud post it ?
datachannel id="#38" name="Omni4barMAP" selected="0" units="psig" min="-15" max="42" expr="0.2369*x-14.7" type="0"/>
<datachannel id="#3C" name="AEM UEGO" selected="0" units="AFR" min="5" max="20" expr="0.03913*x+10" type="0"/>
<datachannel id="#41" name="Load 1Byte tephra" selected="0" units="Load" min="0" max="300" expr="1.3*x" type="0"/
<datachannel id="#86" name="Wastegate Duty Cycle" selected="0" units="%" min="0" max="100" expr="(100*x)/255" type="0"/>
<datachannel id="#8A" name="Load Error" selected="0" units="load" min="-25" max="25" expr="0.15625*x-20" type="0"/>
<datachannel id="#8B" name="Wastegate Duty correction" selected="0" units="wgdc corr" min="-50" max="50" expr="0.5*x-64" type="0"/
<datachannel id="#29" name="Injector Pulse Width" selected="0" units="ms" min="0" max="60" expr="0.256*x" type="0"/>
<datachannel id="#21" name="Injector Duty Cycle" selected="0" units="%" min="0" max="160" expr="[InjPulseWidth]*31.25*x/1200" type="0"/
<datachannel id="#00" name="loadmsb" selected="0" units="load" min="0" max="255" expr="x" type="0"/>
<datachannel id="#01" name="loadlsb" selected="0" units="load" min="0" max="255" expr="x" type="0"/>
redSLed
Jan 9, 2017 05:22 PM
mines5
Jun 18, 2013 09:49 AM
kartectuning
Jun 14, 2012 08:01 PM
fuzzychi
Jul 21, 2010 08:56 PM
xtremeIX
Feb 11, 2008 09:56 AM
