Logging 2-byte Load
Old Jan 23, 2008 | 09:38 AM
xtremeIX's Avatar
Logging 2-byte Load
I have Mitsulogger 1.6 Beta 3 and I'm not clear on the whole 2-byte logging. Does Mitsulogger automatically have the 2-byte setup? What exactly is it? From what I've read it logs more frequently. If Mitsulogger doesn't have it by default how do I set it up?
Old Jan 23, 2008 | 09:55 AM
travman's Avatar
https://www.evolutionm.net/forums/sh...highlight=load
Old Jan 23, 2008 | 11:01 AM
xtremeIX's Avatar
This post gives information on the 2-byte logging but only address's EvoScan. I have made the changes to my ROM for the 2-byte but I'm guessing something would have to be change in Mitsulogger. Anybody know?
Old Jan 23, 2008 | 11:53 AM
roger smith's Avatar
If you made changes to your ROM to get the 2 bytes from requestID 0 and 1 then it should be setup already by default in Mitsulogger I believe. You check your requesid.xml file in the Mitsulogger folder.
Here is what I have for reference
Code:
<Request LogReference="requestID00" RequestID="00" Eval="x" Unit="INT" Logged="y' Response="2" />
<Request LogReference="requestID01" RequestID="01" Eval="x" Unit="INT" Logged="y' Response="2" />
<Request LogReference="2byteLoad" RequestID="FF" Eval="((256*requestID00)+requestID01)*10/32" Unit="2byteload" Logged="y' Response="2" />
Old Jan 23, 2008 | 12:32 PM
xtremeIX's Avatar
No, I don't have any of the tags you mentioned. However, I added your references to my RequestId file and now everything is working great. Thank you!!
Old Feb 9, 2008 | 07:45 AM
EVO8emUp's Avatar
Where do you add the 2-byte tags? I tried various places and the logger stopped working with every try.
Old Feb 11, 2008 | 01:50 AM
burgers22's Avatar
I have the two request ID lines at the bottom of all the other normal requests and the 2byteload line where IDs 0 & 1 are added in the formula below the line that says
<!-- Place all Complex requests below this line
Hope this helps.
MB
Old Feb 11, 2008 | 09:56 AM
EVO8emUp's Avatar
Thanks,
Worked for me.
211Ratsbud
Jan 17, 2022 03:01 AM
Pitside
Apr 29, 2014 04:02 PM
sponners
Jun 10, 2008 04:50 PM
chaz517
Sep 29, 2007 07:22 AM
