Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Jan 23, 2014, 01:12 PM
  #286
NYC EVO's Avatar
Originally Posted by McLaren F1 2003
Does anyone know why this is going on? Attached are my Ecuflash settings and the way my car reads in Scantech. It only shows 3 sensors as ready. Is that right? Even when I set everything to pass, it only shows those 3 sensors.
Thanks in advance!
Did you ever figure out why you only had 3 monitors ready?
Old Jan 23, 2014, 06:43 PM
  #287
3gturbo's Avatar
On my car I cannot get rid of the air injection pump test dunno why, its off in the rom but reports as supported not complete
Old Jan 24, 2014, 08:12 PM
  #288
McLaren F1 2003's Avatar
nope. no one responded.
Old Jan 24, 2014, 08:21 PM
  #289
CDrinkH2O's Avatar
What ROM are you on and what mods to emissions equipment, NBO2, sensors do you have?
Old Jan 25, 2014, 05:14 PM
  #290
CDrinkH2O's Avatar
This is what they should look like.
EV09AWD (May 23, 2019)
Old Feb 3, 2014, 09:58 PM
  #291
randallsrt's Avatar
I fail emissions today with an EVO9 on Speed Density 2.0 3D tune (88592715). I only had 3 monitors that were ready and all other came back as "unsupported"
I even plugged my scan tool into that evo9 that failed and also my personal evo 9 that is also on the 2.0 SD which verified that only 3 monitors were even available and set to pass.
Although the obd Force Passed tables are already implemented into that ROM/XML, no matter what options I choose, nothing changes on my Scan Tool.
I did experiment with another buddies NON 3D speed density patched rom (88590015) and that seems to be working perfectly fine after I patched the XML to display those tables. At this point I'm tempted to just make an emission only tune in order to pass, then switch back to the 3D Speed Density. Unless of course someone has any ideas...
Old Mar 8, 2014, 08:09 AM
  #292
wjamyers's Avatar
Originally Posted by recompile
http://evoecu.logic.net/mirror/vids/
http://evoecu.logic.net/mirror/vids/ecuflash_06.wmv
Old Mar 10, 2014, 05:41 PM
  #293
03EVOGUY's Avatar
i just failed emission inspection in Washington state today, for having TOO MANY monitors in ready mode. I had all of them in force pass mode. so be sure to disable whats in the picture above.
Old Mar 26, 2014, 10:54 AM
  #294
volks-traitor's Avatar
thanks for the washington update, I'll make my changes before going in.
Old Mar 26, 2014, 11:25 AM
  #295
JohnBradley's Avatar
Throwing this out there as a new potential issue. Oregon flagged a car for a VIN mismatch one go around and then it didnt matter the next time, 2005 with 9417 cloned as a 9694.
Old Mar 26, 2014, 06:58 PM
  #296
CDrinkH2O's Avatar
Does that mean there is now a cross check from VIN to original ROM ID?
Old Mar 29, 2014, 03:34 PM
  #297
wjamyers's Avatar
This patch was unnecessary with my setup at the time:
AMSOIL Filter/Vibrant MAF Adapter/Stock Intake :: CBRD BBK Full :: ETS 3.5" FMIC/UICP/LICP :: Synapse Synchronic DV :: MIL.SPEC 65mm Ported TB :: MAP Rev3 IM :: FIC 1100s :: SpoolinUp COP :: MAP Rev2 EM :: BR SS O2/BR SS DP/MIL.SPEC 100 Cell HFC/Tanabe Medalion Touring :: Walbro 255 :: GRC S2 Cams/Springs :: ARP head studs :: Pierburg 3-Port :: CBRD Tuned April '12, making 405whp/345wtq at 26.2psi on CBRD's Mustang with 93octane pump gas
Meaning it passed VA emissions inspection.
Old Mar 31, 2014, 11:42 AM
  #298
Why is my non-continuous monitor completion patch set to EAE5 instead of DAE5 like is shown in you screenshot?
My monitor available and pass settings remain the same either way.
Old Mar 31, 2014, 06:39 PM
  #299
CDrinkH2O's Avatar
Probably because you didn't set it that way
Old Apr 2, 2014, 10:59 AM
  #300
I just passed in Wa. with the above settings, thanks all! I don't yet understand the DAE5 vs EAE5 thing, so I'll keep studying.
Quick Reply: Patch: Force OBD Inspection Pass (acamus, mrfred)
