Data windows resizing?
Old Jul 20, 2009 | 10:55 AM
Nate's Avatar
I'm sure this simple question has been answered already, but after searching last night and this morning, I've been unable to find the answer.
When I open EcuFlash, and click on something like the stationary rev limit, the window opens up too small for me to see the entire value. For example, where I should see "7500", all I see is "7..."
I've uninstalled and reinstalled EcuFlash, without success.
Would someone please point out to me the thing that I'm obviously missing?
Thanks.
Nate
Old Jul 20, 2009 | 02:23 PM
Nate's Avatar
Anyone? Surely I'm not the first person to ask about this.
Old Jul 21, 2009 | 03:57 PM
Nate's Avatar
Please help! I've been unable to figure this out, and it's much harder to clearly edit tables that don't give you more than 1 digit of info per cell.
Old Jul 21, 2009 | 05:40 PM
JohnBradley's Avatar
Something else is going on if you are only seeing something like this 7... and nothing else. You should be able to clearly see everything from 0000 to 9999 and then it goes funny (ordinarily). You can go into the xml and alter the range for RPM but its a little more intense.
Is this all tables or just the rev limit? I think you have a scrambled ROM or something if the latter.
Old Jul 21, 2009 | 05:59 PM
And to answer your original question, you cannot resize the windows.
Old Jul 21, 2009 | 06:27 PM
FresnoEVO's Avatar
i have the same thing but only with the option windows on the obd-II patch tables posted recently; everything else displays fine
Old Jul 21, 2009 | 07:01 PM
Nate's Avatar
Hmmm. I will have to try some other ROM files, then. I'd tried it with three different ROM images, which I'd been able to view without issue in the past.
It happens with more than just the rev limiters - if I try to view the immobilizer info, for example, all I see is the number 3...
One of the ROM images I'm viewing is the one I originally downloaded from the car when I first got EcuFlash about two years ago. The other two are just the same file with minor changes.
Thanks for the suggestions, guys. I really do appreciate it.
Old Jul 21, 2009 | 07:27 PM
I would think there is a scaling issue on yours Fresno.
Nate,
So to change the value in the event it is a scaling issue you need to go to the rev limit window. right click for edit map. Then click on scalings and in this case go to the RPMlimit scaling (or whatever it would be if you thought you had this problem) and go to max value. ECUflash is preset at max value of 9000, but you can alter this higher to read more. If yours is set for some reason at 7000, then you'd see 7... because the last value it will display is 7000.
I think you are probably facing some other software gremlins possibly from a prior tune or something like that. If it had been fine prior then I would suggest loading an older version of ECUflash and seeing what it does. Also make sure to try a few different ROM types if you havent already.
The problem could be an endian issue.
Old Jul 21, 2009 | 08:15 PM
FresnoEVO's Avatar
thanks for the advice; added the blobbits scaling definition to my base evo7 xml file and all is well now
Old Oct 26, 2010 | 09:11 PM
mifesto's Avatar
can you show me the XML to add the blobbits scaling on evo7 base xml?
i thought my ecuflash version 1.42 should have included this scaling in the definitions but i guess not
ez
Jul 6, 2006 06:13 PM
