Question about Bosch 1000cc Injectors
Warm start continues to work fine. In fact, the car seems to start far more quickly than with the oem injectors.
To prove my newbish ways, I haven't touch IPW adder as I have no clue what that is (or that it even existed).
I just installed the moddified Walbro 255lph HP unit and adjusted my latency's and scaling a little bit more. I am at work and did not bring in my laptop so I don't have the numbers handy. I will post more around lunch time.
Question, when I cruised around to adjust Mid Trims I forgot to update Mitsulogger with the scaling numbers I am using. Will this affect the Trim outputs numbers? I am going to spend a little bit more time to make sure the injectors are scaled properly, the numbers are very close now and I didn't want to find out I was way off base.
Thanks.
Dan
Thanks.
Dan
Thanks.
Dan
Thanks.
Dan
Latency and Scaling for me (Stock Fuel Pressure Regulator with Walbro 255 LPH HP). I only run 93 Octane, no E85.
3.816
3.144
1.944
1.392
0.984
0.72
0.504
Scaling: 790
3.816
3.144
1.944
1.392
0.984
0.72
0.504
Scaling: 790
See what your low, mid, and high work out to be..if they go over -5/+5 then you need to work on latency or scaling depending on which trim is off.
What I(we) did was create an Excel Spreadsheet that took the existing values and estimated the values the ECU needs.
Dan
What I will do when I get home is disconnect the battery (to reset fuel trims right? I just learned that today) and go for a cruise and let you guys know what kind of feedback I get.
Dan
Gotcha, so far using Mitsulogger, the values seem to float around -2, 0, +1 and rarely +2.
Dan
Dan
