USB to Serial Compatibility with Vista x64 Bit??
Old Jul 31, 2009 | 10:17 AM
Boost3dxEvO's Avatar
Question USB to Serial Compatibility with Vista x64 Bit??
Hi Guys-
I purchased a Dynex Cable model number DX-UBDB9 from Best Buy.. The drivers that it came with are for "Vista," but I knew that the x64 is a lot trickier to deal with.. so I looked for an updated version of the driver that would be compatible with x64 and I found one . Here is the thing, I plug in the cable and it has to install the driver each time.. then it claims that the device is "ready to use and installed right," but then I check the device manager and it has a yellow flag by it and says that i is not working correctly.. so I try to "reinstall" the drivers from there and it does not install them.. Can some one PLEASE help or recommend a cable that will work with the vista x64 for sure? I need this to be able to log wideband for the lc1 in evoscan.
Thanks so much!!
UPDATE: i solved the problem!
Old Jul 31, 2009 | 04:55 PM
Any body at all?? I really need help here.. thanks
Old Jul 31, 2009 | 10:09 PM
No one can help? I need this cable installed to start tuning asap.. Please help!
Old Aug 1, 2009 | 10:02 AM
codgi's Avatar
Dynex is owned by Best Buy. I'd suggest going in/talking to their Geek Squad and they can hopefully point you in the right direction.
Old Aug 2, 2009 | 10:33 AM
Sounds good, if I cannot figure it out.. I might go this route.. I just figured some one would have vista x64 and a cable that actually works with it or the same cable I have and a way around the issues. thanks
Old Aug 3, 2009 | 07:42 AM
travman's Avatar
I have x64 vista and I loaded a driver I got off the internet after I couldnt get the driver that came with the cable to work.....mine works fine.
I am sure you want to know where I got it......I spent a while on the google searching till I found a driver, let me see if I cant re-dig this up.
Old Aug 3, 2009 | 08:10 PM
Any luck finding it? What process did you go through to install this cable? Did you download the drivers first and then the cable after? And do you have the dynex cable like me? Thanks!!!!
Old Aug 4, 2009 | 08:54 AM
travman's Avatar
Have not found it yet........still looking, going to go through my install files on my computer and see if i still have it.
Yes I have the dynex cable
Old Aug 4, 2009 | 01:08 PM
Okay cool man.. I should be able to get it to work.. Does yours stay installed after you install it once or do you have to install the drivers every time you connect it? Thanks so much!
Old Aug 5, 2009 | 11:23 PM
PROBLEM SOLVED! I reinstalled windows and installed my updated driver.. It installed right away. Thanks for any one that tried to help.. I'm glad I figured this one out on my own!
Old Aug 6, 2009 | 04:50 AM
travman's Avatar
Good deal......glad you got it to work
I found the install file - I had to use a PL-2303 vista driver installer, if you end up needing it pm me and i can email you the file.
Old Aug 9, 2009 | 08:54 PM
That is the same one i used sir
usernameka
Apr 9, 2017 09:30 AM
Danieln
Sep 5, 2010 05:08 PM
brenner
Jan 27, 2010 12:25 PM
lan_evo_mr9
Aug 29, 2009 11:47 AM
evo_gerard
May 21, 2009 06:53 AM
