RC750cc Scaling & Latency
Old Aug 19, 2009 | 09:53 AM
scandinavian's Avatar
Hi all I have an Evo 8 which i've installed RC750cc injectors. Everything seems fine at the settings i'm using except after stoping the car for say an hour it takes longer to restart than normal??
I'm using 696 scaling &
Latency 3.432, 2.256, 1.896, 1.032, 0.792, 0.480, 0.360
(I'm using the stock fuel reg)
Anybody got vales that ae known to work well??
Any help would be great
Cheers
J
Old Aug 19, 2009 | 10:29 AM
fostytou's Avatar
EvoM Community Team
Might be better if you posted here: https://www.evolutionm.net/forums/ec...injectors.html
Your curve is not so much of a curve as it is a bumpy hill.
You could always try the values provided here: http://injector-rehab.com/kbse/lag.htm though they look way lower than where you are at now. Your current values look much closer to what is used on the 1000cc-1200cc RC units.
The startup IPW tables would also be helpful if you have not modified them.
On a side note, If you need to ask any other questions I'd recommend keeping them organized in the other thread and porting (and removing) this post over there. This is probably the last post I'll make here, but I'd be OK to help further over there.
Old Aug 20, 2009 | 09:39 AM
fil78's Avatar
Cheers
J
this is the setting on my IX with stock fuel reg and a walbro255 pump.
works fine with no issues at all and trims within 5%
649.8
5.016
3.12
1.992
1.272
0.72
0.48
0.216
'hope it help
foxbat
Jun 1, 2016 03:02 AM
jameswwt
27
Jun 7, 2012 01:57 PM
Guru Johnson
E85 / Ethanol
Dec 10, 2010 07:35 AM
ikt
Mar 11, 2010 02:50 PM
rdtech
Dec 1, 2009 02:10 PM
